| Group 2 - Body and Interior Headlights, Doors, Fenders, Bumpers, Interior |
Answered: sound-deadening removal help
interior work
Most Helpful Answer - Posted by Aardvaark
Much like Mr. Sweezy, when I cleaned up the old hardened Ziebart asphalt undercoating in the engine compartment of my Manta, I soaked rags in mineral spirits and covered the areas I was working on and let it soak in for 20-30 mins and then scraped the old and now softened asphalt off with scrappers make of wood and some made of plastic. Worked pretty well. I also tryed using a hair dryer (I no longer have use for ) but that just make the stuff far too sticky. I like mineral spirits because it isn't nearly as dangerous or harsh on your skin if any gets on you and it isn't nearly as bad to breath as many other chemical removers. Actually, placing ice cubes in a plastic bag and chilling the areas made the undercoating brittle enough to chip off in thicker areas but was taking too long. Might work with the sound padding too. |
Opel Intern
Well, It wasn't easy, but it was effective. I used a combination of mineral spirits and a non-marring chisel (the plastic type) to scrape up all of the rotted asphalt.
![]() ![]() Provided Answers: 11
Invest in a heat gun from your local hardware store and a putty knife, and plenty of patience and elbow grease.
Opel Intern
I found that heating the stuff up only made the removal more difficult. It would get all gooey and non-cooperative. The mineral spirits kind of just dissolved the bond and the stuff came up in big chunks, rather than messy goo-balls...But of course, I also did this in the middle of winter in an un-heated garage, so I guess the suggestion may be to FREEZE the stuff off.
UFO pel abductee.
-Mark '75 Manta Direct link to my album of Opel related parts catalogs and magazine articles for reference: http://www.opelgt.com/photopost/show...ser/23031/sl/a Last edited by Aardvaark; 06-02-2009 at 10:00 AM. |
Real Name: Ruben Van der Beken
The small bits that I couldn't remove with the screwdriver, I dissolved with white spirit. |
I used a metal scraper and lots of hard work. The angle of attack (scraping) makes a big difference. I wasn't worried about scratching the paint as I was already planning on painting the floor before laying down my Damplifier (AMAZING stuff btw.)
I used some prep all (basically mineral spirits) gloves and a ton of rags to clean up the residue. A lot of people recommend using dry ice to freeze the sound dampening to ease the process. |
![]() Provided Answers: 10
Once you take the tar off, you will need to clean the area and seal it with a rust inhibitor prior to installing the carpet. You can get a can of bedliner or rubber undercoating and cover the area to protect it. If you don't protect it, it will start to rust through and you can see it in less than a year.
