Installing sport spring!
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Like Tree16Likes
Thread: Installing sport spring!
    Super Moderator My location Ooooner's Avatar
    Concord, North Carolina, United States
    2,778
    Roy Bell
    4
    Errrrrrrr..... 😡 Im replacing the stock leaf spring with a sport spring. I've got the old leaf spring loose with the tension off of it. I've got the passenger side lower A arm down but the drivers side must be possessed. The two bolts that hold the lower A arm to the cross member will not budge. I have the nuts off. I've used heat, beat on it, prayed, you name, I've tried it... it's like it's welded on! Any suggestions?
    Roy Bell
    1969 Opel GT (Switzerland)
    1973 Opel GT
    1972 Opel 1900 Wagon
    Carolina Opel Club
    Nov 2007
    Cöllingswööd, NJ
    9,707
    Gördö
    6
    Since you said you "have the nuts off" I guess you're meaning the vertical bolts that pass through the cast iron thingy. I presume that your bolts go in from the bottom and the nuts were on top. If that's the way they were, then I can't imagine what could possibly still be holding the lower A-arm to the cross member:
    The crossmember is only 1/8" thick, there shouldn't be anything except a little rust holding the cast iron piece to the crossmember and the bolts sticking out the top.
    Unless some ding-dong put the bolts in from the top and they're rusted solid to the cast iron.
    Then yer screwed and you'll have to sell the car.
    Try smacking the head of the bolt(assuming it's on the bottom) with a sledge hammer. Bolts pull upwards against the threads of the nutting or bolt hole. It sounds counter-intuitive that hitting an already tight bolt like a nail would do anything, but the trick does work. It fractures the crystalization of the rust. Those bolts are super heavy duty hardened steel, by the way. Put a big ole pipe on the end of your wrench and yank on that baby. If the bolt snaps, OGTS offers new ones. Or Harold can dig through the chicken poop and fetch ya some from his barn.
    Oct 2002
    Mahopac, NY
    4,040
    Uh...Oh. Who wants to buy my car..................
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35 BMW Z4
    Mar 2012
    Frozen Tundra
    5,135
    James
    mine too.
  7. #5
    2,778
    Roy Bell
    4
    Well, some ding dong ran the bolts from the top. The bolts are simply part of the cast iron thingy now! I've started drilling the bolts out from the bottom and that's a pain in the ole butt.... I'm assuming the bolts are probably grade 8 or better... I'll keep you posted...
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  8. #6
    Mike's Opel Shop Site Supporter My location opellane's Avatar
    Apr 2004
    Goshen,New York
    899
    Quote Originally Posted by Ooooner View Post
    I my opinion you should not worry......just burn off the top of the bolt head with cutting torch and it will be free...
    Then worry about getting them out of the cast thingy
    MIKE
    1973 MGB, Red, Weber 38DG
  9. #7
    Dec 2009
    Germany/Bremen
    2,726
    Norbert
    For a good mechanic,that will be correct!
    Otherwise you can lost the whole bolt,when the nut go lose!
    hrcollinsjr likes this.
  10. #8
    Jul 2005
    Milner, GA.
    11,264
    Dan
    12
    I.. I.. I can't help myself..
    Sport springs are for young people.
    Us older chaps likes smooth saddles...just sayin Right Roy?
    Ooooner likes this.
  11. #9
    2,778
    Roy Bell
    4
    Quote Originally Posted by opellane View Post
    Have you seen where the bolts are on the drivers side? I'm not sure a cutting torch is the way to go... I'll get this thing. It's not going to whip my a$$!
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  12. #10
    2,778
    Roy Bell
    4
    Uh... what you trying to say? 👍
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  13. #11
    Jul 2005
    Milner, GA.
    11,264
    Dan
    12
    opelgtguy and Ooooner like this.
  14. #12
    Aug 2006
    Goderich, Ontario Canada
    2,688
    P.J.
    Everybody has his own recipe how to free rusted bolts. I have great experience with 50:50 Acetone/ATF mix. Soak those bolts generously and leave it overnight.
    On the subject of sport spring, use intermediate one, 2” lowering spring is way too hard for a street use.
    Ooooner likes this.
  15. #13
    Can Opeler Knorm65's Avatar
    May 2014
    Wichita Falls and Munday, Texas.
    1,739
    Kyler Norman
    4
    Have you tried getting an impact wrench on them at low power with a flex or u-joint attachement? If you spin them they may free up. Or double nut it on the bottom and turn it with a wrench.
    Ooooner and The Scifi Guy like this.
    "Mira," 1970 Opel GT ARA AC, European 2.0L and Weber DGAS
    "Kara," 1972 Opel GT Targa "Fancy Rat Rod"
  16. #14
    Nov 2007
    Cöllingswööd, NJ
    9,707
    Gördö
    6
    Uh...Oh.(I'm a ding dong) Who wants to buy my car..................
    mine too. (I'm a ding dong)
    Yuk! Yuk! Wah! Ha! Ha!
  17. #15
    Nov 2007
    Cöllingswööd, NJ
    9,707
    Gördö
    6
    Forget the drilling. Drop the front suspension so that you can get those bolts out properly. You'll spend way more time and cuss words trying to get them out on the car.
  18. #16
    Oct 2002
    Mahopac, NY
    4,040
    I would drop the suspension as suggested. You are going to have to do a PERFECT job drilling them out and that is almost impossible for such a long bolt, but you are into it now. If you go off center you will cut into the cast steel part because the bolt is so hard.
    Ooooner likes this.
    www.markandson.net
    www.gpny.com
  19. #17
    2,778
    Roy Bell
    4
    That's where this is heading! I've installed these springs before, while the suspension was in the car and with it out. Never had much of a problem before. One side came out great. But, nooooooooo, the other side is filled with hate and Satin.
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  20. #18
    Dec 2009
    Germany/Bremen
    2,726
    Norbert
    When I remember,I only screw off one side for change my springs
  21. #19
    2,778
    Roy Bell
    4
    If you only screwed off one side, didn't you have to trim the rubber bushings off on the old spring to get it to slide through? That might work....
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  22. #20
    Nov 2007
    Cöllingswööd, NJ
    9,707
    Gördö
    6
    I'm thinking the same thing as Norbert. You should be able to swap out the spring with just one arm detached.
    Ooooner likes this.
    1. sport seats
      By Jeroenvdd in forum 2B - Seats, Windows and Interior trim
      Last Post: 01-29-2011, 10:51 AM
    2. Front Sport Spring installation question
      By Bud K in forum 3A - Front Suspension
      Last Post: 08-28-2010, 01:44 PM
    3. Sport Mirrors
      By turbocon86 in forum 2D - Body Repairs and Modifications
      Last Post: 10-12-2009, 03:51 PM
    4. 75 Sport Wagon
      By kent in forum General Discussions
      Last Post: 06-21-2006, 11:00 PM
