Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 4 - Propeller Shaft & Rear Axle
Group 4 - Propeller Shaft & Rear Axle Differential, Propeller Shaft, Central Joint, Rear Axles
Old 09-18-2006   #1 (permalink)
David12345 is on a distinguished road
Unanswered: tools
Is there a name and/or size for the tool to remove the torque tube from the differential?
David
David12345 is offline
Old 09-18-2006   #2 (permalink)
12-point
I think you mean the four cap screws that hold the tube on to the diff housing.
They have a head with 12 little 'points' inside them usually - though they do get replaced with ordinary in-hex Allen Head metric capscrews by frustrated Previous Owners.
The 12-point ones are also known as "Tri-square" (three squares = 12 points).
If you do much work on your Opel you will need a set of these special tools - PowerBuilt has a kit of them as does K-D Tools. 6;8;10 & 12mm sizes will cover all the sizes on a GT.
See: http://www.opelgt.com/forums/41791-post12.html
Old 09-18-2006   #3 (permalink)
ddoyle
MAC tools also carries a full set, and they are very nice, around 45 bucks, i think.
Dan
ddoyle is offline
Old 09-18-2006   #4 (permalink)
As usual, thanks for the info .. but I am curious, why would you replace them with normal hex heads instead of a regular bolt?
Thanks again.
David
Old 09-18-2006   #5 (permalink)
Thanks again.
David
Probably because the dreaded PO tried to remove them using an 'Allen" wrench and screwed up the interior of the original bolt.
Old 09-19-2006   #6 (permalink)
Strength ....
Thanks again.
David
Allen Head ("In-Hex") Cap Screws are much stronger than 'regular' Metric bolts and ... from memory ... the torque tube bolts are countersunk into a wee round hole just the size of a Allen head capscrew head.
Allen head because both the replacement capscrews and the Allen Keys are MUCH easier to find!
Old 09-19-2006   #7 (permalink)
blancojp's Avatar
Provided Answers: 10
seerated tool bit
Nappa sells the tool in three different sizes, 8mm, 10mm and 12mm.
They are called " Serrated tool bits" and cost about $5.00 each. Some people (old school) call them tri-stars but the correct name is above.
Hope this helps.
JB
'70 Opel GT - 4 speed "Lucy"
blancojp is offline
Old 09-19-2006   #8 (permalink)
"Triple Square", they have 12 points! "Serrated Bits"
Old 09-19-2006   #9 (permalink)
The same tool will get the bolts off of the camshaft sprocket when you get into that project...
When the "compact carnage" was over and I had some fixing to do, I discovered that the torque tube bolt holes could be tapped to 3/8" and then I could use my favorite bolts there, you know, the good old 12 point shouldered capscrews. Worked like a charm.
jeff denton is offline
