Unanswered: Brake pad question
When putting brakes pads into the caliper how easily should they slide in? Should you have to tap them into place? Also, do all cars come standard with the spacer pieces? When I took the pads off the front brakes on my GT they didn't have spacers. One of the rotors was messed up bad so I had to take one off of one of the other GT's and I noticed that it had spacers in alongside both brake pads.
#2 (permalink) | |
Because the disc brakes are self-adjusting, when changing the pads, the caliper pistons have to be reset to allow the thicker/new pads to be installed. This means pushng them back into their bores, to allow the new pads to be slid in place. This can be done with a C-clamp or by carefully levering them back with judicious use of a pry bar. When the pistons are forced back in their bores, brake fluid may overflow out of the brake master cylinder. HTH.
The pistons should be clean before squeezing them back in. Harold |
Thanks for the help guys, I'm waiting for the cross-shaped retaining pieces to get in at the parts store tomorrow so I can put the brake pads back in and secure them. After that is checking all the lights.
Speaking of which, on the dash panel there's like 5(?) circles that are supposed to light up, some with different colors. What do these indicate? |
The 5 little circles are two rows, upper having three and lower having two. The upper outside two are for you turn signal indicators, they are green. the middle one is white, indicates when your headlights are not correctly closed or open. The lower row, the left side is blue, for your hi-beams, and the right is red for e-brake/low brake fluid/clutch adjustment.
