Type "A"
Unanswered: Wheel cylinder rebuild
Also, I have a new master cylinder and the front brake cylinders that I'll be putting on in the next day or two. Any advice for putting those on? Do I need to try and blow the old fluid out of the lines? Thanks all! |
Call Yerby Brake Supply in Sacramento, CA @ 800-878-1461. I spoke to him last week and he still had a couple of Kadett wheel cylinders he can't get rid of. These are new OEM that have been taking up space on a shelf since the 70s.
Type "A"
I haven't had much luck with auto parts stores - can't even get a 6V battery without putting one of my kids as payment.
The curse and beauty of the type A has been it's individuality. It's a chore finding parts but since nobody else wants them thay aren't too expensive. The guys at Yerby are going to call me back tomorrow. Thanks for the tip. |
No....its not a Buick....
I had a 6 volt truck (47dodge 1/2 ton) and batteries were plentiful at the local tractor retailor aka farm and fleet. Last one I bought was around 30.00.
Shouldnt be difficult to find one in your area..... Joe |
UngerDog
I'm going to resurrect this thread to ask this question that I couldn't find the answer to with the search engine.
When rebuilding the rear brake cylinders, do you glue the rubber cups to the pistons? If so, what do you use? Jerry |
Trouble Maker
Real Name: Tony Holcomb
I found it's not really worth it to rebuild the cylinders when it's like 5 more bucks for band new ones.
#9 (permalink) | |
No, you don't glue the cups. Basically, if your cylinder is clean, by that , I mean, no pits or whatever, then run a little new, clean brake fluid in the cylinder, then your cups, facing in, with the spring in between the cups, pistons behind the cups, then the end covers.
"Yes, I do have a rifle rack in my Sportwagon" Last edited by kwilford; 10-08-2009 at 12:02 AM. |
Real Name: gerold
Poochycor,I don't know if you have your brakes done already, but what I try to do when I work on my cars is to update and improve on the stock parts. You might want to check if the Manta 3/4 inch cylinders will work on your set-up. I have swapped out most of mine already- many parts will go into the others. The extra diameter will give more pressure on the shoes, hence, better braking and safety. The fact that you are saving a ton of money by doing the labor yourself will allow you to spebd a few bucks for better quality parts. The payoff is longer wear and ultimately money saved.
