2 seats is enough
Low or no vacuum to brake booster .. does car move? are brakes locked up ? Maybe M/Cyl. or flex line clogged up and holding brakes on .
HTH John
No....its not a Buick....
I once had the same type of thing happen when I inadvertantly put the in line booster valve thingy in backwards. Turned it around and problem solved.
Might be somthing to look at if you took it out recently. Joe
When I got my car it had a really hard pedal. Rebuilt brakes: rear flex hose was clogged shut, that alone accounted for the hard pedal, it still stopped fair on one good and one sticky front. If rear's are clogged, half your volume of fluid isn't moving so pedal is twice as hard? Don't know reason, but you can check if the rear's are operational easier than messn' with booster I'd think.
"Being ignorant is not so much a shame, as being unwilling to learn." Benjamin Franklin Last edited by jvandyke; 07-17-2007 at 08:09 PM. |
