Group 5 - Brakes Disc, Drum
Old 09-06-2007   #1 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Unanswered: Squeaking Brakes
I have replaced my front rotors with new ones, replaced the pads with ceramic pads and rebuilt the calipers. Now, when I apply the brakes, there is a squeaking noise. What can be done to eliminate the squeaking? Someone said that I could take some very fine sandpaper and go over the new rotors and it should stop. Sounds fishy to me!
Anyone with any thoughts? As always, thanks for everyone's input!
Roy Bell
1973 Opel GT
74 Manta Rallye
Concord, North Carolina
Carolina Opel Club
OMC
Ooooner is offline
Old 09-06-2007   #2 (permalink)
Detritus Maximus
If they squeak when the brakes are applies, as opposed to all the time, you might want to give them a little time and miles. I replaced my old rotors with new ones (Brembos from Tirerack). I reused my pads as they were fine.
They began squeaking within a few miles. The more I drove them the more they squeaked. This is apparently my pads bedding in to the new rotors. After awhile, the squeaking stopped. I guess whatever profile the pads had from the old rotors had to be worn away until I had nice full pad contact.
If this is not the case for you, you might try sanding the corners and edges of your pads. Give them a slight radiused edge where they contact the rotors. It doesn't take much really.
Are you using shims? Stock brakes? '75 brakes? Or?
"No, it's not fiberglass."
opelbits is offline
Old 09-06-2007   #3 (permalink)
Roy;
There are some thin metal plates, that mimic the pads shape, they slide in behind the pads, between the pad and the piston, they will stop the squeak. Or you can get this gooey stuff from the parts storethat you smear on the back of the pads. Basically it glues the pad to the piston and stops the squeak. Sanding the pads does stop the squeak, but only till they smooth out again.
Old 09-06-2007   #4 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Yes, I am using stock brakes and I did put the shims in place. Just like you had mentioned, it started to squeak after only a few miles. I may just try to stick it out for awhile and see if it runs itself out. If that doesn't work, I will try some of your other ideas.
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 09-06-2007   #5 (permalink)
Roy, as previously mentioned the shims are supposed to help. If it really worries you buy some of the "goo" and place a little between the shims and the backs of the pads. Did you replace the retaining hardware when installing the new pads?
Old 09-07-2007   #6 (permalink)
SpringGT's Avatar
Did you clean the new rotors with solvent prior to installation?
Most of the new rotors that I have bought recently have had a laquer (or some type of) protective coating on them, I presume to prevent rust formation until they are sold. I had to wash the rotors in lacquer thinner, as the coating felt soft enough to possibly glaze the pads if left intact.
SpringGT is offline
Old 09-07-2007   #7 (permalink)
Mike Preble's Avatar
Ear plugs. My wife said it worked for my snoring!!! LOL
Mike
Mike Preble is offline
Old 09-07-2007   #8 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
SpringGT,
I did not clean the rotors off and yes, there was some sort of coating on them. That may just be the problem! Thanks... I will clean them off and see what happens.
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 09-07-2007   #9 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Mike
Good idea, Mike! If you can't hear it and the car stops, what's the difference?
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 09-07-2007   #10 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Harold,
Yep, I replaced all the retaining hardware when I installed the new pads. The shims that came with the new pads had a "peel off" backing so you could stick the shims to the pads before sliding them into place. Worked great! But SpringGT mentioned that there was a coating on the new rotors and I did not clean it off. I will try that and see what happens.
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 09-07-2007   #11 (permalink)
Harold,
... But SpringGT mentioned that there was a coating on the new rotors and I did not clean it off. I will try that and see what happens.
Ah, the coating is most likely in/on the pads by now, but maybe not no more than you've driven it.
Old 09-07-2007   #12 (permalink)
Mike
A pillow works also, it just depends on where it is placed.
Old 09-08-2007   #13 (permalink)
It might just be that the pad material and rotor hardness don't match well. If you put semi-metallic pads on a BMW 325 they squeak like crazy, put the OEM pads on and the problem disappears, but your black wheel syndrome re-appears (personal experience). Maybe your pads are just too hard.
markandson is online now
Old 09-08-2007   #14 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Jeff,
You may be right but I cleaned the "new" film off yesterday. I removed the new pads and cleaned them, too. We'll see if that is it. If not, I may have to go to the OEM pads. Thanks...
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 09-08-2007   #15 (permalink)
73Manta72gt's Avatar
73Manta72gt
Roy, get a set of greenstuff pads. I put them on all three of my cars
73Manta72gt is offline
Old 09-08-2007   #16 (permalink)
soybean's Avatar
I used the same on mine with no problem as well. Jarrell
soybean is offline
Old 09-08-2007   #17 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Helmut,
Were did you get the "Greenstuff" pads? I may just give those a try if these ceramic pads keep squeaking.
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 09-08-2007   #18 (permalink)
Roy
I bought mine from Brake Rotors | Car Brakes | Ceramic Brakes | Disc Brakes | EBC Brakes
But if you go to EBC Brakes - Home of the worlds largest range of brake products you can find all of the dealers and shop around...
You should be able to find them under $40 and some places have free shipping for orders over $50 ...
Greenstuff pads may dust a bit, but it cleans easier than semi-metalic pads. The tiny metal bits will embed in the paint of the rim and are neer impossible to clean
Paul
Paul is offline
Old 09-08-2007   #19 (permalink)
73Manta72gt
I'm not sure where I got them but they cost about $30 I haven't really noticed any brake dust from them. The $9ones from autozone & advance produce a lot of dust.
