Unanswered: 73 Manta Brake Question
TMK |
#2 (permalink) | |
I may be wrong, but, it looks like the two different resv will fit the M/C you have, it just that the the two bowl one is OEM, and the other is something off a BMW or Audi that has a low fluid sensor in it, hence the two wires coming out of the cap.
Detritus Maximus
Hey Tom-
On my 74 the reservoir looked like the one in the first pic. It used retaining clips down in the fluid ports to hold it onto the master. Unless there is some other press-fit type rubber seal that can be used with the 74-ish master, then by looking at the other reservoir, it cannot be the later type. Opel used a GT style ATE master the first couple of years on the 50 series, then switched to the AC France unit (marked Delco AC France and has a brake warning light switch) in 72 (model year according to the parts book) with Bochum chassis #2761478 and Antwerp 9662825. I would hazard a guess that you have the earlier master that shares internals with the 67-72 Kadett/GT master. Even the reservoir cap should be interchangeable with the cap on your Kadett, but only if the Kadett is a stick. Automatic Kadetts had a different cap. As a side note, if you have the earlier master, you have the earlier model 50 brake booster. As far as I know, they are a matched pair. Early booster/late master or vice versa are not compatible. Count yourself lucky, you have a cheaper easier to deal with master than the AC France.
