Lempi: Feared by all Walleye
Unanswered: Master Cylinder-brakes
Jo Anna
We know more than we know we know. |
There's also been a thread on using an Eagle Talon M/c and a Honda m/c. blancojp on this site seems to have the "skinny" on all this, try contacting him.
master cylinder
There's one on ebay rightnow!
eBay.be: Opel GT Hauptbremszylinder ,Kadett B ,Opel, ATE, (object 190167753105 eindtijd 04-nov-07 19:30:00 CET) Eddy |
Detritus Maximus
Unless you have your heart set on a new master, I'm sure I have extras suitable for rebuilding.
You could be the answer to my prayers--! My son leaves in a week and is wondering if he truly can do a rebuild before he leaves.....gosh almighty--things sure get complicated in a hurry!!! Jo Anna
Viking
Real Name: Hallgeir
#9 (permalink) | |
Not Difficult to Do (within a week)
What you need to start with, is a rebuildable US GT master cylinder, which is commonly available as a used part (core exhange value is under $50.).
Then install new seals from the rebuild kit (it is suggested that you buy from an Opel retailer, as saving a few dollars from a "generic" online source, means you probably won't get same-day shipping, well-written instructions or necessary reservoir seals with their kit). |
![]() Provided Answers: 10
many many options!!!
Jo Ann:
There are many options to chose from when replacing a master cylinder, I should know since I had over 20 different units installed on my car. If you go the BMW route, a unit from an E30 will work just fine however the connections are on the left side instead of the right. Most of the other units you can install requires you to drill two mounting holes closer to the center, allowing you to bolt it on to the stock brake booster. If your vehicle is stock, I recomend you use a Honda master cylinder and a "tee" for the front circuit. I posted all of the particulars here some time ago. If your vehicle has been modified with vented brakes or 4-wheel disk brakes like I have, use the Acura equivalent which has a bore of 15/16". Otherwise a 13/16" unit with a bit of creative thinking will get you back on the road just in time to put your car away for the winter.
#12 (permalink) | |
Detritus Maximus
Tony P.
I hope you get it worked out so the GT is ready for next year as we need a Michigan meet and I personally would love to run to the UP. This is first year I can remember where I didn't run up there at least once. Bugs me.
Nuts!
We have a company in town who bore out master cylinders and fix in a stainless steel sleeve to restore old, rusted ones - never have to be fixed again! They also do wheel cylinders and disc brake calipers too.
Here is a clip from Hemming's Motor News: The same options would apply to your original master cylinder. Repair kits can be purchased to repair your original, or you can resleeve the master cylinder in the same way the wheel cylinders would be fixed. Several advertisers in your latest issue of Hemmings Motor News can perform this service for you. Many cylinders can actually be improved upon by the installation of a stainless-steel sleeve. The stainless steel resists rust and pitting much better than the stock cast-iron bore. You will have to pay extra for this type of repair, but it will last many times longer than the conventional repair would. The cylinder bores are actually oversized to accept the new sleeve, which is press-fitted or adhered to the new bore dimension. Advertisers who can perform stainless steel sleeving include Karp's and Apple Hydraulics. The cylinders would be equal to the original specifications, but with the added advantage of the stainless-steel bore. KARP'S Power Brakes Upland, California 909-985-0800 Apple Hydraulics Calverton, New York 631-369-9515
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 10-30-2007 at 02:12 PM. Reason: Added info |
#15 (permalink) | |
and would I need to replace all four brake lines? Sorry I didn't get back to you sooner--so much going on to prepare for winter, etc.!Great big wads of Opel Smiles, Jo Anna PS--about that Michigan Meet idea--Brockway Mt. Drive is the only place to be at the end of Sept. first week of Oct. for the stunning Fall colors!!!
Karp's and Apple
The primary problem as explained to me by Ron Karp (owner of Karp's) in sleeving the Opel master cylinder is the use of the small chamber below the main bore of the master cylinder. This houses the valve for the brake warning switch. Evidently, the orifice feeding this is offset enough that assess without an offset drill is not possible. The cylinder can be sleeved but this switch will no longer function as designed. It does not affect the master cylinder function. I have three Manta master cylinders there at this time to give him test beds to come up with a solution. So far nothing. These have been there about a year.
#17 (permalink) | |
There are at least 3 Opel parts suppliers in the USA who will provide you with OEM parts, new or remanufactured Opel parts. If you can support these companies it is greatly appreciated by the owners, I can assure you it is. Opels Forever |
#18 (permalink) | |
Bob |
You can also remove the piston assembly from the switch chamber and install a pressure unit. I have done it this way many times and works the same way.
I frankly don't care about the switch, it is very hard to feel assured by a dash light that you don't have brakes when you are crashing into something. In any event, NAPA has two in the main warehouse and it is part# 111-541.
#20 (permalink) |
Is that the one that winds up to the overview above Copper Harbor? If so, you'll want your brakes working for the trip back down!
#21 (permalink) | |
![]() I visited my son (100 miles south of here) and MY OPEL this weekend and he is flying out Monday for Texas and returns for 4 days after 2 weeks in Amarillo. Hoping to have a cylinder for him to work on when he returns. Snow is predicted for all of the coming week and even tho' the clocks turned back an hour this morning and gave us one more hour, we fear we'll run out of time.... ![]() Cheers! Jo Anna
#22 (permalink) |
Detritus Maximus
Hi Jo Anna-
Sorry I haven't gotten back to you sooner. So much going on. I will post a pic of what I have later on. Tony P.
#24 (permalink) |
Real Name: Jon
Not 100% sure if it's for a GT, but there is one on eBay right now. Item #190170226798.
Jon
