Group 5 - Brakes Disc, Drum
Old 03-16-2008   #1 (permalink)
redronin's Avatar
redronin is on a distinguished road
Unanswered: stiff brakes....
So as well as many of my friends, I noticed that it takes a lot of force to push down on the brakes...... also when I hit the brakes the car starts to idle lower.... I checked the one way valve and it works, I also changed the hose that connected it but it didn't make a difference..... do the brakes need to be bled? is the booster bad?
redronin is offline
Old 03-16-2008   #2 (permalink)
No....its not a Buick....
yellaopelgt's Avatar
Is this an automatic or manual trans? Usually when idle is affected its a vacum issue......One time I accidentally put the check valve in backwards and the brakes were VERY hard and pretty much non exsistant. HTH
Joe
yellaopelgt is offline
Old 03-16-2008   #3 (permalink)
How old are the brake hoses?
These little cars didn't stop very well even when new IMOA.
Old 03-16-2008   #4 (permalink)
It might be a bad booster, trouble shooting req'd.
Old 03-16-2008   #5 (permalink)
redronin's Avatar
Its a manual trans and I think the brakes are the originals but it does look like some of the lines are new.... I checked the one way and its on right.... and I think the leak is from under my carb.... How do I check the brake booster? I heard some are dangerous to take apart....
thanks
redronin is offline
Old 03-16-2008   #6 (permalink)
long time Opeler
deaner's Avatar
An easy way to check your brake booster. With the engine off, pump the brakes a few times. With your foot pressing on the brakes Start your car, the brake pedal should travel down a little bit more. If it doesn't your booster is bad. Brake boosters are not serviceable and should be replaced.
deaner is offline
