| Group 5 - Brakes Disc, Drum |
#27 (permalink) |
highschoolopelproject
If the disks are warped, how would I true them up if I can not turn them on a lathe? Plus I'm not paying for the bits, the school does. I don't want a wobble when I apply the brakes.
Last edited by jordan; 04-13-2008 at 11:23 PM.. Reason: re-editing what I previously edited |
#28 (permalink) |
If the brake rotors are warped they must be turned on a lathe, if turning them requires more material to be removed than the minimum material condition allows then they are junk.
1970 Opel GT 1.9
1980 Moto Guzzi V50 2000 Saab 9-3 2.0 turbo 2000 KTM 200 exc STOLEN |
#29 (permalink) |
ok well i think i have been striaghtend out. I will not remove the 4 bolts that are now stripped, due to the unfindable seal. I will remove the caliper as a whole with the two bolt located on the back side, then check the thickness and possibly remove some material if i can. Then paint the unmachined surfaces, with special heat paint, but red not black. Thanks for all your help!
#30 (permalink) | |
You're right Harold I forgot to mention the 6 mm that you don't need for the Opel
Groetjes, Greetings, Grüße:
Only built from 1970 until 1975 ![]() Daily driver: '72 Ascona 2.0 Luxus Automatic |
