Opel Forums
Go Back   Opel Forums > Technical Forums > The Main Tech Forums > Group 5 - Brakes
Group 5 - Brakes Disc, Drum
Old 05-31-2008   #1 (permalink)
BlitzGT's Avatar
BlitzGT is on a distinguished road
Unanswered: Brakes pull left
Calipers are good (last I checked) But when you apply the brake...the car REALLY wants to take you left...HARD. last time I drove it was over a year ago, and I got used to correcting with the steering, but I think my dad is going to give me a green light to start fixing little things on it. Does this sound like a common problem or am I missing something simple?
BlitzGT is offline   Reply With Quote Top home
Old 05-31-2008   #2 (permalink)
heimue's Avatar
It sounds like a very common problem. Get new brake hoses. The old ones swell up and block the flow of brake fluid.
Dieter
heimue is offline   Reply With Quote Top home
Old 05-31-2008   #3 (permalink)
5,000 Post Club
Front brakes are self-adjusting, so it could be the rear brakes need to be looked at and adjusted. The other possibility is the hoses to the calipers. They have been known to collapse internally and become one-way check valves, which could also be the cause of your braking problems.
Old 05-31-2008   #4 (permalink)
BlitzGT's Avatar
That is probably the one thing I didn't check...I'll see if I can get it into the shop tomorrow. Thanks for the suggestion.
Old 05-31-2008   #5 (permalink)
It's easy enough to check brake application if it's that bad. Jack up the front end and spin the tires and have someone hit the brakes. It sounds like the left one is working better than the right one since it's pulling that way. If you bleed the front brakes the right one probably won't have much fluid coming out of the bleeder screw because of a restricted hose.
Don't just replace the hose that you think is bad, REPLACE ALL THREE OF THEM!
hrcollinsjr is online now   Reply With Quote Top home
Powered by vBulletin® Version 3.7.3
