Group 5 - Brakes Disc, Drum
Old 07-07-2008   #1 (permalink)
opelspyder's Avatar
Unanswered: Caliper sizes???
Okay, starting to wonder how many caliper piston sizes Opel used on US imported cars. I count 4 now
1 Manta 75 models and 1900s
2 GT
3 Kadett 1.9 and GT 1.1
4 Kadett 66-67
Are there any others? The 66-67 measured slightly smaller than the later 1.1 and Kadett 1.9 pistons, from NOS parts I've had, but now really wondering.
Keith
opelspyder is offline
Old 07-07-2008   #2 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
From my experience:
The Kadett 1.1L caliper is the same as the GT 1.1l caliper and is smaller in diameter than the 1.9L calipers.
The Kadett 1.9L caliper is the same diameter as the GT 1.9L caliper which is the same diameter as the 1900/Ascona/Mantas.
The early Kadett B used a smaller diameter caliper that doesn't directly interchange with the rest.
oldopelguy is offline
Old 07-07-2008   #3 (permalink)
opelspyder's Avatar
Kadett Calipers
I assumed the Kadett 1.9 Calipers were the same as a GT with 1.9 as well. But guess what, they are NOT!!!!! Found out the hard way this weekend when I started disassembly of them. Turns out they are the same part number as a 1.1 GT, as my new seal kits were way too big. I will put the GT ones on it due to the seals I ordered. But you might want to check again as well. I am learning quickly that the Kadett and the GT share less and less in common.
Keith
Old 12-14-2008   #4 (permalink)
Killer Texas GT's Avatar
The "Piston" diameter for the 1.9 Kadett, GT, Manta and Ascona (including the 75"big brake) is 48mm. The "Piston" diameter for the 1.1 Kadett and GT is 44 mm.
The 1.1 calipers are also smaller in physical size and mounting bolt pattern compared to the 1.9s. The "75 big brake" is larger in physical size than the typical brake caliper from a 1.9, but has the same bolt pattern mounting.
rk
69 GT 1.9/4 Spd
73 Manta Rallye
OPEL WERKS
Killer Texas GT is offline
Old 12-14-2008   #5 (permalink)
Gordy's Avatar
I went to the Tire Rack and just ordered the proper rotors for the 1975 brake set up so there should be no issues. They've got a good selection of Koni and KYB shocks as well. Ordered the calipers from Rock Auto at $45 each.
Gordy is offline
Old 12-14-2008   #6 (permalink)
The posts on upgrading to larger rotors were off-topic, so I split them off to
http://www.opelgt.com/forums/perform...tml#post180258
