Opel Forums
Go Back   Opel Forums > Technical Forums > The Main Tech Forums > Group 5 - Brakes
Group 5 - Brakes Disc, Drum
Old 08-18-2008   #1 (permalink)
hotrodder1969 is on a distinguished road
Unanswered: brake booster
ok i just removed the brake booster and i have alot of brake fulid in it i think there should be a seal between the master cyl. and the booster am i right and if so dose anyone have a rebuild kit for both the master and the booster thanks for any help with this
hotrodder1969 is offline   Reply With Quote Top home
Old 08-18-2008   #2 (permalink)
Paul
Brake fluid in the booster is a sign the rear seal in the MC is shot and the MC needs rebuilding... OGTS or Opel USA...
Paul is offline   Reply With Quote Top home
Paul
Old 08-18-2008   #3 (permalink)
Detritus Maximus
Classified Rating: 100% (1)
As I recall, there is a seal/boot or something but if you have fluid in the booster, then the master is leaking (which is a different seal).
The master rebuild kit is available from several places. The booster would need to be sent out for rebuilding. I had Vanco in California do mine and I am very happy with it. Probably about a $125 for that. If your brakes have felt fine and operated okay, the booster probably doesn't need anything. Just make sure the seal at the vacuum fitting is sealing properly.
opelbits is offline   Reply With Quote Top home
"No, it's not fiberglass."
Powered by vBulletin® Version 3.7.3
