Unanswered: single pot vs two pot calipers
I bought the car with the ate(?) two pod (48 or 40mm) calipers installed and non ventilated 248 disks. I also have a pair of later single pod (54mm?) manta b gt/e calipers lying around. The question is which setup is better, single pot or two pot calipers on my manta. Excuse me for my english and thank you in advance. |
In my opinion you don't have a dilemma at all
![]() Most people I know who bought cars with the single pot "floating" calipers have converted to the older two pot fixed caliper type. In ideal conditions I guess there isn't too much difference in performance between them for road use, however the "floating" types are very prone to seizing up due to corrosion unless well maintained, meaning that during light braking you would pretty much be using just the pad on the piston side, and then you stomp on the brakes a bit and the caliper moves and you get both pads working, however when you release the brakes again....they're once again stuck, but now with the pad on the opposite side of the piston dragging until the movement of the disc frees them up again, but this leads to excessive pad wear and the possibility of warped disks, not to mention uneven braking action side to side....ugh, stay away, they were a horrible design if you ask me The only thing that would make me consider running the floating type is if they came off a Rekord 2.2i along with the ventilated disk
"The nice thing about standards is that you have so many to choose from" --Andy Tanenbaum-- |
If the single pot calipers are of the earlier type I would prefer the two pot fixed caliper ones. I believe they will give you less problems. Harold |
I believe they will as long as you get the complete brake assembly, but you will need to run 14" or bigger wheels
