Group 5 - Brakes Disc, Drum
Old 01-18-2009   #1 (permalink)
R8Gordini
Real Name: Paul
r8gordini is on a distinguished road
Answered: Kadett 1.1L caliper needed in Vancouver, Canada
I think I found a new replacement caliper for the kadett 1.1 disk brakes.
Unfortunately my car is in Europe and I am in Vancouver, BC Canada.
I need a 1.1L caliper to be able to compare if this new caliper will fit.
Are there any members in this forum from Canada, or close enough to Vancouver, that have one of these calipers that I can borrow in order to be able to compare ???
Alternately, if anyone could measure up a 1.1L caliper and send me the measurements.
Paul
Last edited by tekenaar; 01-24-2009 at 01:50 PM. Reason: Is there any members . . . that has
r8gordini is offline
Most Helpful Answer - Posted by Killer Texas GT
tried redoing to be more legible but size will not load so here are the measurements:
A) 56.48mm + or -
B) piston is approx 44mm
C) 15.7mm
D) 14.5mm
E) 37.7mm
F) 123.53mm -(E)
there is no bleeder hole in caliper
I hope this will work as good as a picture.
Old 01-23-2009   #2 (permalink)
R8Gordini
Real Name: Paul
Is there really no one that can help me ??
Old 01-23-2009   #3 (permalink)
I don't know for sure, but, I'm sure someone will correct me, but, did the 1.1 Kadetts HAVE front disc brakes? I thought that was just the 1.5 and up?
BQS4 is online now
Old 01-23-2009   #4 (permalink)
heimue's Avatar
Yes and no. The early small engine models (1.0, 1.1) were available in Europe with drums as standard, or discs as an option; and the later models (~71...72), and all 1.2 liter and up had discs as standard. I don't know about the US models, if the question comes up.
Dieter
heimue is offline
Old 01-23-2009   #5 (permalink)
heimue's Avatar
What dimensions do you need? You mean you have a different brand or different model caliper, and want to compare basic dimensions?
I can also check for you on German ebay, and even help with making the payment since almost nobody accepts paypal in Europe.
Dieter
heimue is offline
Old 01-23-2009   #6 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
My coupe has disc brakes on the front, it's a '67.5 with a 1.1L, and so does my '71 sedan with a 1.1L. Looking at them, they look exactly the same in every way as the regular pre-'75 calipers except for having a smaller bore for the pistons.
Given that, I can't think of any reason to keep and use the 1.1L disc calipers myself. I'd rather swap them out with the 1.9L calipers for a little more brake pressure and a little softer pedal.
oldopelguy is offline
Old 01-24-2009   #7 (permalink)
R8Gordini
Real Name: Paul
Wow thanks for the replies.
My Kadett is 1.1L with disk brakes.
I made a rough drawing of measurements I need.
I have included an attachment in jpg format of the drawing.
The idea is to be able to compare and see if it will fit and clear all relevant areas. So measure everything you can and let me know.
It needs some minor grinding to make it fit... well see, but if it works we would have brand new available calipers to replace the old ones.
Thanks Paul Silva
Last edited by r8gordini; 01-24-2009 at 04:02 PM. Reason: replys - Queen's English? . . . attachement - French? ;-)
Old 01-24-2009   #8 (permalink)
Not the Same!
I have a 1967 Kadett Rallye 1.1SR with factory disc brakes - the calipers are not the same as 1.9L GT ones. Both the puck (piston) size is different (45mm vs 48mm) and the distance between the two mounting holes is closer on the 1.1 calipers.
I tried to replace mine with 1.9L GT calipers and they would not bolt up. That means that the spindles the caliper bolts to are also different.
Did not measure anything at the time except to note that if you want to use the larger 1.9L calipers the spindle has to be swaped out as well to get them to fit - and that poses difficulties as well for the earlier ball joints are different too!
The discs themselves are the same.
Old 01-24-2009   #9 (permalink)
Killer Texas GT's Avatar
This may help
measurement from a caliper that came off a 1.1 either 66 to 68 model Kadett. Not sure which one it came off of. There is no bleeder valve opening on this caliper. the Piston measured roughly 44mm as it is still in the caliper and could not get an accurate measurement. Hope this helps.
Jim is correct on changing out to a 1.9 caliper on a 1.1 equipped Kadett. Gene the 1.1 Rallyes had the disc as standard equipment, all other 1.1 Kadetts came with drum brakes on the front with discs as an option. My 66 Kadett was loaded with all options including the disc brakes.
rk
69 GT 1.9/4 Spd
73 Manta Rallye
OPEL WERKS
Killer Texas GT is offline
Old 01-24-2009   #10 (permalink)
R8Gordini
Real Name: Paul
I am not trying to install 1.9L calipers. The calipers I found are for a different aplication, and I think they are about the same as the 1.1L calipers
thats why I need the measurements.
I opened the attachment in Photoshop but I can't read the numbers its all too fusy. So I resaved the origional JPG as a PSD file and if you could insert the measurements again I would apreciate it.
You will have to go back to the old message and download the new format.
Thanks Paul
Old 01-24-2009   #11 (permalink)
differant approach
A) 56.48mm + or -
C) 15.7mm
D) 14.5mm
E) 37.7mm
F) 123.53mm -(E)
rk
69 GT 1.9/4 Spd
73 Manta Rallye
OPEL WERKS
Old 01-27-2009   #12 (permalink)
R8Gordini
Real Name: Paul
Thanks Killer Texas
Its enough information to know that it will probably work.
I will buy a pair and take a chance. I will report back to the forum with all the fitting details, it will be either this fall or next fall depends when I go back to Portugal.
Paul
