Unanswered: 74 Manta master Cylinder
Autozone shows this kit for a 74 Manta:
AutoZone.com | Shopping | Parts | Product Detail - Master Cylinder Kit (Brake) I got a kit for my GT at Autozone last summer. Special order but it only took a couple days to come in. Don |
Real Name: Jim
![]() Provided Answers: 7
Duane (MantAscona) knows a place in Virginia that bores and relines master cylinders with brass sleeves for not too much $$. I can't think of the name but if you search or PM him I'm sure he'll tell you.
Jim
![]() Provided Answers: 10
I have a few Opel master cylinders in stock, some used and some rebuilt. But I believe you should consider the Geo conversion since you will have better functionality and easier to get components. As an example, you can get a Geo master cylinder on Ebay for less than $30.00 all day long. You can also use a Honda master cylinder if you are considering installing rear disk brakes in the future. Make sure the master cylinders are from non-abs cars, makes the installation simpler.
Stay tuned, I will be installing one in my Ascona pretty soon!!!
No problem, one of my partners in crime will be doing this in detail!
I lined up th Geo MC and the Manta boster and the bolt pattern are the same. Cool.
The only issue is the depth the Geo MC goes into the booster. I would love to see this conversion 'cause I need to replace mine and I have a Geo one availale.
Master cylinder kits.
The problem with the Manta/Ascona master cylinder is often not the seals. It fails or leaks due to pits in the bore of the cylinder. The M/C body is cast iron and will, or has corroded through exposure to the elements. It can even corrode if not exposed. Many people do not flush their brake system periodically and the fluid collects moisture over time.
Anyway, you can try White Post. I called once and they were right on board until I told them what it was for. They put the brakes on quick. They would not guarantee a rebore due to the nature of the passage arrangement in the Manta M/C body. There is some sort of offset fluid passage in the M/C. They will overbore the hole in sleeve and get close on the rebuild however. It is better than nothing, or at least that is how they addressed it with me. You can call Ron Karp at Karp's Power Brake Service (909) 985-0800 and see if he ever finished any of the M/C' s I sent him. He had two or three to experiment with, but I never heard if he got a good fix or not. Good luck, Dave |
I just found 2 kits that I will be buying. Not cheap though. Rockauto has them cheap but Gil at OGTS has had them on backorder from them for 6 months.
Do you have a pic of how the Geo MC fits on the booster?
#15 (permalink) | |
I don't understand what you mean by depth into the booster. I would install the Geo Mater cylinder on the booster and measure the preload if any. This is the amount you need to cut off from the inner booster stem. Once done, you can put the master in place, it should go all the way back to the booster wall with no effort. I then press the pedal and the master should move forward with little or no play.
Kalifornia Kid
Sept. 1970 to mid year 1973 the Manta uses (originally) a ATE Master Cylinder, same as the 1968-1973 GT, but with a different fluid reservior.
Booster Bolt Spacing to Master Cylinder is: 2 3/8" {the rear piston sticks out from the master (hollow) which engages the booster rod} Mid-Year 1973 thru 1975 (end of production) Manta used a Delco Master Cylinder, (Ie. GM standard). Booster Bolt Spacing to Master Cylinder 3 7/16" {rear piston is dimpled to receive the booster rod} Note: I do not have the chassis number switch from early to late style. If someone has it,... we can add this to our knowledge as Opel owners.
#17 (permalink) | |
