Group 5 - Brakes Disc, Drum
Old 04-28-2009   #1 (permalink)
gtkid2 is on a distinguished road
Answered: brake pad removal
how do I remove the front brake pads? do I have to split the caliper? thanks!
interior work
gtkid2 is offline
Most Helpful Answer - Posted by Aardvaark
One thing that should be mentioned is that even big brake shops
and professional mechanics seldom rebuild calipers themselves. Rather they usually send them to a local brake rebuilder who has the parts and equipment to restore the piston bores properly if needed.
While I do replace brake pads and have rotors turned myself if needed,
I take any caliper rebuilding to the local brake rebuild who usually has them done the same day if taken in by noon. And the cost which usually isn't too bad includes "loading" with new pads which you can either use or replace with better ones. The shop I use has been in bidness forever and even has
rebuilt exchange calipers for some Opels ready to go.
In the meantime while waiting for the calipers to be finished, I repack the hubs and have any rotor work done.
IMO, it just isn't worth the time, work and mess to rebuild the calipers and wheel cylinders myself for what the local shop that caters to the mechanics will do it for.
Jmo.
Old 04-28-2009   #2 (permalink)
Provided Answers: 11
Nope, you drive out those two pins you see. Use a punch, and go from the outside towards the inside of the car. Then you slide the pads out.
Old 04-28-2009   #3 (permalink)
jlthunder's Avatar
Gene is correct. Don't split the caliper, it will never go back together without leaking. Knock the pins out. New ones are available from OGTS, or Opel JIM, if they are shot.
It will be your easiest pad changeout. (well, almost, my wife's 99 civic was really easy, one bolt and the caliper hinged open)
1973 GT, Parted out, R.I.P.
jlthunder is offline
Old 04-28-2009   #4 (permalink)
AZManta's Avatar
Real Name: Tom Esterkin
To do the job properly be sure to repack the wheel bearings and machine the rotors (and check thickness).
AZManta is offline
Old 04-29-2009   #5 (permalink)
Sparky73's Avatar
Real Name: Jon
Sparky73
And check those darn rubber brake lines! Seems like every GT I've had needed them replaced. They will collapse inside making them pretty much unusable.
Current
1970 GT; Under Construction
Previous
1969 GT; Street/Strip Project
1969 GT; Black Parts Car
1969 GT; White Parts Car
1972 GT; Red Parts Car
Sparky73 is offline
Old 05-28-2009   #6 (permalink)
everything came apart ok... so what do I rebuild on the calipers if I can't split it? or can I do work to it without splitting it? thank you!
interior work
gtkid2 is offline
Old 05-28-2009   #7 (permalink)
What he said plus the rear!
Old 05-28-2009   #8 (permalink)
You can get the pistons out with a little compressed air and a block of wood. You do not need to split the calipers to rebuild them. Actually the seals for the caliper halves are NOT included in the rebuild kit, so if you split them you'll be SOL
Paul
Paul is offline
Old 05-28-2009   #9 (permalink)
UFO pel abductee.
Aardvaark's Avatar
Jmo.
-Mark
'75 Manta
Aardvaark is offline
Old 05-29-2009   #10 (permalink)
I'll see if there are any shops around my area... thank you for the response!
interior work
gtkid2 is offline
