Group 5 - Brakes Disc, Drum
Old 05-22-2009   #1 (permalink)
el mero mclain
opelmario's Avatar
opelmario is on a distinguished road
Unanswered: vacuum leak at brake booster
hello opelers. tried tuning my car but it seems that i have some kind of vacuum leak from the valve that connects to the brake booster. now, mister killingsworth was nice enough to give me the valve while he was passing thru el paso, tx. BUT i'm wondering is there some grommet or some rubber washer / bushing that goes in between the valve and the brake booster? if so, please let me know where i can find one.... mr. collins.....mr. killingsworth? anybody there?
it's not a lowrider, it's an all nighter!
opelmario is offline
Old 05-22-2009   #2 (permalink)
No Mario, we're all hiding from you. IIRC you had an issue with the rubber grommet where the elbow goes into the brake booster. Or it may have been the elbow itself. I remember trying to get one out for you and finally concluded that I was going to break it before getting it out. You can obviously disconnect and plug the vacuum line at the manifold and see if that cures the problem. If it does you can reconnect the each section of the vacuum line and plug the end to try to figure out where it is leaking. If you are using the original vacuum hose as I suspect you are, I'd go ahead and purchase a new one anyway. Holler at me if you want my number is the same or I can call you if you would like. Good luck!
HTH,
Old 05-23-2009   #3 (permalink)
el mero mclain
opelmario's Avatar
sir its the grommet, where can i find one?
Old 05-23-2009   #4 (permalink)
West Coast GT's Avatar
West Coast GT
1st call should be the Opel GT Source 1 800 673-5487.
Are you talking about the Vacuum Booster Inlet Seal?
West Coast GT is offline
Old 05-25-2009   #5 (permalink)
el mero mclain
opelmario's Avatar
if its the seal that goes with the valve that you twist on to the front of the booster, then yes! let me know where to find it.
Old 05-25-2009   #6 (permalink)
OPEL PARTS GREECE
alpharm's Avatar
alpharm is on a distinguished road
It is sold as a set with the rubber gasket and the plastic pipe
For the moment i have this set at 12 Euros
E-mail: alpharm@otenet.gr
Online: (MSN users-Windows Live Messenger): Opelparts@hotmail.com
Skype: Opelparts
alpharm is offline
