Answered: help with rear pistons
interior work
Most Helpful Answer - Posted by hrcollinsjr
#2 (permalink) | |
Uber Genius
I just pulled mine apart last weekend. Its pretty easy if you don't have a lot of attachment to the internals of the wheel cylinder. It's a pretty simple unit, really. You have a metal piece in each end. Behind those are rubber cups and inbetween the rubber cups is a spring. I just tapped them all from one side through to the other. Nothing was damaged but I am replacing the cups anyhow since they are cheap (get 5/8). The brown powder is brake fluid infused oxidation. There is a good chance that your wheel cylinders are toast if you have a lot of that powder. New wheel cylinders are less than $30 at the parts store I go to (knechts).
#3 (permalink) | ||
Yes , Brake parts and W/Cyls. are cheaper than Sheet metal any day.
Uber Genius
Fyi
If you ever want to replace the wheel cylinder cups (before you have to replace a wheel cylinder) the Raybestos part number for 5/8 cups is WCC2530
It is a box of 10 so you will have a few to spare.
Rebuilding rear wheel cylinders is fairly practical, UNLESS the pistons are corroded as they are hard to come by (they were at one time part of a standard rebuild kit, but not so much anymore), or if the cylinders themselves are pitted more than just slightly. From what is described above, those wheel cylinders are toast.
JM2CW
#8 (permalink) | |
Uber Genius
Replacing the cups is best done as a preventive measure and not a corrective one, unless your pistons and wheel cylinder bore are in excellent shape. Maybe someday someone will take a lathe and cut a bunch of wheel cylinder pistons someday. Of course as long as the wheel cylinders are still being sold new, there isn't really a need.
ANY decent tool store that carries wrenches should have a flare-nut wrench, either individually or as a set. You need a 10 mm version IIRC.
#11 (permalink) | |
Mid-West Opeler
Just saw a set of three (3) at menards for about $15. Didnot look to see if they were metric
I bought a set for $12 at advance auto... new pistons make me wonder why i considered rebuilding the old ones
![]() rear brakes almost done now... oh and did I mention line wrenches are my new best friend?
interior work
