Unanswered: my brakes don't make any sense!!
![]() i am really deserate to get the car back on the road since the old Dodge get's only 8 mpg.
Did you check for line leaks at all four corners of the car and at the M/C?
If there are no system fluid leaks, it sounds like the M/C or the lines still have air in them. Did you bench bleed the M/C first? Or did the M/C reservoir run dry during the bleeding process, thereby reintroducing air into the system? If it is not air in the system, then you may have a bad M/C rebuild and are slipping fluid around the piston cups. It is more likely to be an air problem than a M/C problem since the M/C is new. IMO. Bob |
With all the stuff you have replaced it almost certainly is the master cylinder even if you rebuild one, the sleeve has to be spotless for the new seals to push fluid. If you have no fluid on the ground at any of the wheels then most likely suspect is the master cylinder. I sent three MC to be rebuilt only 2 out of the 3 were able to be rebuilt all of them looked good to me when I sent them in. They even replace the reservoir rubber seals on the top.
This is where I sent mine and they did a great job cost me 30 bucks each and 5 dollars for the one that could not be rebuilt for an inspection fee. Auto Parts Fast at RockAuto I've seen a lot of pricy rebuilt ones, some over a hundred totally ridicules , save your money and try rock auto. Most you will be out is 5 dollars and shipping. Recommend them to everyone they did me such a great job.
Or get one from Opel GT Source. They stand behind their parts
Old rubber brake hoses can create a spongy pedal too. Also make sure the pedal rod is adjusted properly. You will loose pressure through the reservoir port till the piston passes the port. If you do not have enough piston travel past the port you will not get full breaking function.
well, i did bench bleed as best i could and there are no other leaks from the lines that i could see. when i started the rebuild i was careful to get everything out and back in right and the inside of the cylinder looked good to me. i did look at Rockauto and was considering that, was just hoping i could get this going quicker but apparently not. my economic situation was also dictating that i try all home remedies first. i was wondering...what are the 2 small screws for on top of the M/C just under the resevoir. those don't have anything to do with bleeding, do they?
I somehow missed that you had done the M/C rebuild yourself in your original post.
When you rebuilt it, did you hone the bore of the cylinder or just clean it up and install new cups? The bore gets polished inside where the cups move back and forth and this glazed surface needs to be honed out until you have a uniform "matte" surface on the full length of the bore. Otherwise the new rubber parts will not seat properly and fluid can slip around them. Buy a brake cylinder hone at a part store, hone the full length of the bore back and forth, then shine light into it and look for shiny areas in the bore surface . Continue this process until the entire bore surface has a uniform dull surface and all shiny areas have been eliminated. Clean and flush the abrasives out of the M/C, reinstall the new rubber parts and re-bleed everything. HTH Bob |
Opelitis since 1984
Real Name: Charles Goin
I had a similar problem.. the MC was good.. but it wasnt bleed right and it had air stuck in it. Have you tried bleeding the master again?
Then after re-bleeding it with a vacuum pump, I lifted the rear end high in the air and let the front sit low.. cracked the rear wheel cylinders and let it gravity bleed overnight using the little bottles with the magnet on the back (at advance autoparst for $6) and made sure they were higher than the master. That seemed to have gotten it for me.
#10 (permalink) | |
#11 (permalink) | |
Uber Genius
The Rock Auto rebuild would pay for itself in ONE tank of gas! (OK, maybe a tank and a half)
Opel GTs are not GM products Last edited by kwilford; 06-16-2009 at 09:34 PM. |
your correct, depending on tank size, I was just pushing the point that values are of no effect if your hurt while debating cost.
#13 (permalink) | |
![]() Provided Answers: 10
I then hook up the rear brake line and start the bleeding process. When the rear is fully bled and the E-brake is adjusted properly, the pedal will have little travel and will be hard as a rock once again. It is now time for the front system so attach the front lines and bleed the front brakes. Again, when all of the air is out of the front circuit, the pedal will have little travel and will be hard as a rock. The final step is to lock the brake pedal in place with a rod. This will serve as if someone is pressing the brake pedal continuosly which will allow you to check for leaks. At 1000psi of delivered pressure, a thought to be tight connection will develop a leak. Hope this helps.
i am definately not driving the car yet. i value this car more than me at the moment. i didn't hone the master when i rebuilt it. i can try that and try the bleeding process again
i've still got a couple days off to try that and see what happens.
I have two of them and never used them, do not trust them at all.
well, i have definately done everything now. i pulled the M/C back off, pulled it apart, honed it, checked my seals, put everything back together, bench bleed, and installed again. had someone help with bleeding the lines, have no air anywhere and no leaks. re-adjusted the rear shoes. the E-brake works but it is up at the top of its height, but it does hold the car very good. my pedal is still low. its is very solid but low and the car does stop. here's a question: is there any adjustment on the rod in the booster? i could not see how it would adjust if there is. on my 78 dodge p/u, there was a simple procedure to adjust the pushrod length for the M/C.
#18 (permalink) | |
Uber Genius
BUT, first adjust the E brake. If the Ebrake isn't adjusted properly, you can have problems.
#20 (permalink) |
Uber Genius
This explains how to adjust brakes, both at the pedal and the rear brake shoes.
Opel File Downloads - The Classic Opel Forums The rear brake shoe adjustment is on page 6 and 7.
#21 (permalink) |
I FINALLY GOT IT!!!!!
![]() ![]() i tried everything evrybody said, covered all bases and you wouldn't believe what it was. today after adjusting the E-brake(5 clicks and solid), i looked at the pedal again. it was then that i noticed this little round thing with a funny cut-out in it and realized that is why i have some free play in the pedal. that's the spacer thingy that the bolt goes through to conect the booster. now i just have to put a few miles on the car, ENJOY IT, and the recheck my rear shoes and, of course, find something else that needs to be done to it. control arm bushings come to mind right now but not sure i want to do that just yet. with my luck i'll probably mis-place the control arm and spend a week finding it.
#22 (permalink) | |
Harold |
