Opel Newbie, Truck Oldie
Unanswered: Brakes? Um...what brakes?
Been a long time since I've posted here
![]() Anyway, FINALLY getting back to working on the Opel. While it's been parked, for some reason, it has completely lost all braking. Can't even hold itself on a driveway! The pedal goes down with very little resistance, and what there is feels like a return spring (feels identical to the clutch, actually!), not hydraulic load. Should we start at the master cylinder and work our way down from there? |
IOwnCalculus
1970 GMC C1500 350/700R4, 15.83 @ 86.92 (corrected) Uh, my girlfriend has a '73 GT... |
good idea...
you may have bad brake lines and they are leaking alot of fluid.... Check resonator and see if it has fluid. if you have fluid check for leaks. if you have no leaks then its gonna be the brake booster or the master cylinder. I found out the hard way.. but always buy new rubber brake hoses when you do a brake job. I've just got done with my brakes. for good parts go to Opel gt source, or napa, or heck i bought some of my brake parts off of people from this site..(good people)... well anyways it cost me $390 doing it myself... I had to buy...
special tool for rotors.-8.50 wheel bearings and seals.-60 original replacement rotors. 38 each- 76 total rear wheel cylinders-56 each, shoes -15 set and hardware(springs )-8.50. used Calipers and new pads, and the drums "turned"-for all- 58 And the caliper and backing plate grees and brake fluid.-12 front brake hose's- 15 each - 30 total |
From what little I could see in the resivoir, there was plenty of fluid. There's certainly no brake fluid leaks where the car's been parked for ages.
Everything appears to be working fine as far as the booster. Wouldn't that cause a nasty vacuum leak? Despite being probably about a year since it was last fired, she came right back to life once I got the battery topped off and fuel reached the carb again... |
IOwnCalculus
to be safe...
it looks like your gonna have to do a complete overhaul of the brakes. start with the master cylinder to be safe. i never heard of the booster to go out, but i guess it can happen. you can have napa order you a master cylinder brand new for only 35 bucks......
That's what I was thinking...I might do the hoses too since they're probably old, and they're relatively cheap to replace.
I must say, I like Napa's pricing on this stuff
IOwnCalculus
