#26 (permalink) |
another option if you have a good core
#27 (permalink) |
Who would rebuild the master cylinder? I think that Autozone told me that but then said that they had no way to actually send my part to someone who would rebuild it. I did get a rebuild kit that is supposed to be for a '72 GT there though. Not expensive either.
I did several searches in the recent past for all posts and threads started by blancojp for Geo master cylinder, Metro master cylinder, Geo Metro master cylinder, Metro, Geo, etc. and no threads turned up about a Geo master cylinder bolting right on and working with a stock Opel booster or with a stock brake system. There were references to other Geo parts like an alernator, etc. I did notice that in some searches most of the things that turned up were actually posted in the last couple of weeks. Maybe some older posts don't turn up in a search? There are many broken links for pictures, etc, in other threads. Do you know the name of the thread? The ones about Honda and BMW parts seem promising too. One thing about searching is that you have to read and read and read and read before you dig up the blanket statement that a certain part will just bolt right on, no problem and only if you read and read and read and read some other threads you might also find mention that you have to bang out the inner fender or might not be able to use your headlights, etc. To me, 80% or 90% of the purpose of this website is so that anybody who wants to own one of these cars can readily get useful information that other people have learned so you don't have to find it out by trial and error, or by buying the wrong parts. It would also be more useful if threads and posts got more accurate titles about the subject. Too often they might get titles that don't help when using the search function. |
#28 (permalink) |
I'm not convinced the booster is really needed. Especially when using a larger master cylinder??
I left the booster out of my system when I moved the pedals back, and incorporated the stock master cylinder into the pedal assembly. Not that I use brakes much, but when I do, there isn't a lot of effort needed to lock up the wheels.
#29 (permalink) |
You can and should rebuild your stock Opel GT master cylinder. I say this because no one here is going to accept any responsiility for you installing anything else and doing it wrong, and if you aren't comfortable with some trial and error then anything but stock is just not for you. There are no alternatives other than the stock GT master cylinder that do not require at least some amount of fabrication skills and modification, nothing else was designed for the GT and will work directly.
To rebuild the Opel master cylinder you need a quality internal snap ring pliers and a brake cylinder hone. Sears sells both under their Craftsman line, and the hone should come with instructions. You will need to remove the master cylinder from the booster and while applying a little pressure to the cneter of the piston from the input end with something (I usually use a 1/4" drive ratchet extension) you will have to remove the internal snap ring from the cylinder and carefully release the spring tension to pop all the parts back out. After a good cleaning with brake parts cleaner you will then need to follow the directions on the cylinder hone and resurface the inner wall of the master cylinder. Once it is smooth you then replace all the soft parts on the assembly you removed with new ones from the kit you purchased, lube them up with brake fluid, and reassemble the master cylinder. Bench bleed the master cylinder to fill it with fluid and make sure it's all working properly and reinstall. If that's all beyond your available skills, time, or space, or you need the booster rebuilt as well, swing into a book store and purchase a copy of Hemmings Motor News. Inside there you will find a dozen companies that specialize in rebuilding the master cylinder, the brake booster, or both. I would recommend one in NH I have used twice before, but I don't have the information handy. If you do want to continue research on modifying your master cylinder you need to understand basic hydraulics. You are applying pressure with your foot on the end of a cylinder in order to raise the pressure in it and move a little fluid to the wheel cylinders to force them to apply brakes. In order to apply those brakes you need both a certain, fixed, amount of pressure and a certain, fixed, amount of volume. If the stock master cylinder is 13/16" diameter, and moves 3/4" to actuate the brakes you can calculate the volume, and the pressure only matters in relative terms. Say you replace the master cylinder with one that has a 3/4" internal diameter. Now, because of the reduced surface area on the piston you are pushing on, you need to apply less force to get the same pressure, or force per unit area. You also, though, because of that same reduced size, need to move the cylinder further to move the same amount of fluid out to the wheels, say an inch instead of the previous 3/4" (I'm not going to do the math, but you should.) That means your pedal will be further towards the floor before the brakes actuate. Several companies in the70's and even now used master cylinders made by the same company that made the Opel master cylinders. You can physically bolt several of them to the booster, but none that I know of have the right kind of fluid reservoir because the application in the nose of the GT is unique. That means you either modify the reservoir on the new master cylinder or adapt an Opel one to it, neither of which is super easy. The easiest way to find out what you're up against is to search somewhere like partsamerica.com for various master cylinders, look at their pictures, then compare them to the Opel one in person. I would start with BMWs, 2002 and 3-series, and then move on to Volvo and VW. You also need to worry about brake line locations and residual pressure valves, but those can be adapted later if need-be. Try to find something with disc brakes on one end and drum on the other, and you should be OK. As to the booster, all it does is amplify the force your foot exerts on the master cylinder. The GT and 1.9 Kadetts use a roughly 2:1 booster, and the 1.1 Kadetts with disc brakes use a roughly 1.6:1 booster, which means for every pound of force you apply with your foot the booster is roughly doubling that force on the master cylinder. Let's say you use a master cylinder with a smaller bore than stock, as above that requires less force to achieve the same fluid pressure. With a small enough bore, and a strong enough foot, youmay find you don't need the booster at all. (I don't use them myself, I swap to a 5/8" bore master cylinder and eliminate the booster all together, but since I use a pair of them with a balance/bias bar between them and have to make my own brackets it's not something I'm going to recommend to someone else for liability reasons.) All the booster has to do is fit in a location between te ebrake pedal and master cylinder and hook up to the input shaft. If you're considering replacing the master cylinder, getting the booster that matches the master cylinder makes good sense as you will know they bolt together. As to mounting it up, you need a way to bolt it into place, usually that's either a pair or quartet of bolts that you may or may not have to drill or file the holes in the mounting bracket for. The only other mechanical connection is the push rod from the pedal, and all you need there is to make sure you got the one for the car that the booster came from and cut it somewhere, then cut the Opel GT one somewhere, then have the two of them welded together. You may need to pay attention to where the pedal is and do some careful cutting, and you want the welding to be professional for safety. Attention to detail is rewarded, and sometimes you get lucky on length or such and can thread one shaft to screw into the other so no cutting will be required, but that's a case-by-case thing.
1958 Rekord Sedan, 1958 Olympia Wagon, 1959 Opel Olympia Sedan, 1967 Kadett Coupe, 1967 Admiral Sedan 4L CIH-6, 1968 Kadett fastback 1.1L, 1970 Kadett Wagon Turbo 2.2L, 1971 Kadett Sedan 1.1L, 1975 Manta Wagon 4.3L V-6 Last edited by oldopelguy; 07-16-2008 at 12:47 AM. |
#30 (permalink) |
Good info. There is no liability issue. But if someone says a part is a reasonable replacement and "bolts right on" they should then also go on to say....but you'll also have to modify this and this. Anything else is just incomplete.
#31 (permalink) | |
I'm not going to comment about the search engine except I have similar issues with it. It has helped me a lot and when not I ask people, very helpful and you get a lot of opinions, you just have to pursue and find what works for you. Hope that helps |
#32 (permalink) |
Dennis:
The price you quote to rebuild the master cylinder is not bad. Hopefully your's is good enough to rebuild. Getting it relined later (stainless steel or brass?)would probably not be a bad idea. I just had mine rebuilt using the kit that Autozone sells. The kit was $20.99. I've actually been finding recently that Rockauto and some of the other places on-line also do NOT list the appropriate Civic or BMW master cylinders as being in stock either. That surprised me. With all this, getting your Opel master cylinder rebuilt this way is not a bad deal at all and it keeps your car stock if you want it that way. |
#33 (permalink) | |
size?
I have more to rebuild I just needed two right now, I'm sending them 2 rebuildable cores and asked if they would make me up a kit for the rest they (person I spoke with) didn't sound too keen on that idea but he had no idea since it is jobbed out. From what I have found, it is a good price to have it rebuilt for me, of course shipping will add to the figure. What size was your kit from autozone? the piston size? Did it work and feel good? That is good information and price since no shipping would be involved. Thanks The explanation they gave me on the size (since opel GT are power disc as they say it only fits) is that they use different venders and sometimes do to no working knowledge they just have various kits. It did not sound like a reasonable explanation but I am sending the MC's in this weekend for rebuild. As far as being stock items, it appears there are too few rebuildable cores out there to have enough stockpiled for sale. Thanks |
#34 (permalink) | |
![]() Provided Answers: 10
I have installed the Geo assembly on vehicles with front 2.5" diameter pistons and 11" rear drum brakes with 1 1/8" wheel cylinders. Never had a single problem with cars under the 4000Lbs range. And if you do a search on the web for Ford Falcon brake upgrades, the Geo mastercylinder/booster combination is the recommended cheap upgrade to a car that is over 3000Lbs. Everyone says you must use a proportional valve and so on. What everyone misses is that on most of these Jap master cylinders, the unit comes balanced for 60/40 operation due to the placement of the inlet port, in respect to the outlet. So nothing else is needed besides a 10lb residual valve for the rear which with the emergency brake properly adjusted, I don't believe is required and I never used one. Though I no longer have an Opel with a front mounted master cylinder, if anyone would like to see how it is done just let me know. I can show step by step what needs to be done to mount a Geo master to the Opel booster. If all you need is a stock master cylinder or booster, I have a good qty of new, rebuilt and used units in stock.
#35 (permalink) | |
Yes pleas show us. I have a 94 Geo Metro in my driveway right now and am looking to do this exact mod.
#36 (permalink) |
Yes, this would be very good to know. These parts should be readily available too for awhile. The one I saw, which Sawdust posted a picture of seemed to be very compact. There are two setups (in general) one up front and one on the firewall. Both would be interesting to know more about. I think the one up front and on a stock booster would be best with less modification. I would also think that the Geo mc and booster could be placed up front too.
#37 (permalink) | |
If mounted as a combination (Geo booster/mastercylinder) up front in the stock location, you will need to make a brake rod adapter. This will set you back a good $1.25 if you have the tools.
#38 (permalink) | |
I received my parts back today one master cylinder was not able to be rebuilt (charged me 5.00 labor for inspection) but the other they did a bang up job on, cleaned everything and even replaced the grommets for the reservoir to clip on to. Total cost was 28 bucks and shipping was another 11 something (actually that was shipping for both I sent 2 of them) to ship it to them. Just for information, and it is recent received them back 8/07/08 JFI |
| Tags |
| m/c, master cylinder |
