Shim or no shim
Results 1 to 16 of 16
Like Tree4Likes
  • 1 Post By norbertone.gt371
  • 2 Post By norbertone.gt371
Thread: Shim or no shim
    Super Moderator My location Ooooner's Avatar
    Concord, North Carolina, United States
    2,727
    Roy Bell
    4
    Shim or no shim
    I'm putting new brake pads on my 69 GT with the "Green" pads from Opel GT Source. I noticed that they already have a metal shim attached. Of course, the old ones have the loose metal shims. Should I use the old shims with the new pads? The old shims have two raised "brads" that seemed to go with the piston on the caliper. Any thoughts would be appreciated.
    Roy Bell
    1969 Opel GT (Switzerland)
    1973 Opel GT
    1972 Opel 1900 Wagon
    1974 Opel Manta Rallye
    Carolina Opel Club
    Oct 2002
    Mahopac, NY
    3,957
    Quote Originally Posted by Ooooner View Post
    When you say the new pads have the shims "attached" do you mean you can't take them off? I would not use two shims if that is what you mean. Other than that it would be personal preference and would not make any difference if you used the old ones as long as they are in good condition.
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35 BMW Z4
    Dec 2009
    Germany/Bremen
    2,633
    Norbert
    Thats the problem when owner went to modern stuff without thinking!
    But they didn´t know that the pistons in the calipers must have the right build in direction with a tool!
    Those shims beware for that the piston can turn and destroy the rubber seals!
    And other problem will be! Then the pads make noise like a pig OINK OINK
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    The pistons in the '75 50 series calipers were uniform with no flat spots in them for the notched shims you're referring to. If/when I catch a break I will attach pictures of both to help clarify what I'm referring to. Both early and late pistons are 48mm.
  7. #5
    Dec 2009
    Germany/Bremen
    2,633
    Norbert
    There are more piston designs over the years!
    But the question was for a 69 european GT
    Ooooner likes this.
  8. #6
    2,727
    Roy Bell
    4
    Right... The new pads have a thin metal piece that is part of the pad. I guess it's epoxied on or something like that. Can't be taken off. My concern was that the old shims have the tabs on them and they fit into place with the piston and the new ones don't have the "tabs" I'm assuming thats done to keep them moving around?
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  9. #7
    2,727
    Roy Bell
    4
    I got these from Opel GT Source so I assumed they wouldn't sell me something that would't work on the GT. Making me wonder now. Don't want my GT to sound like a pig?
    Norbert... Which shims are you says will turn? The shims on the new pads are fused on the pads. I guess I was wondering if I could use the old shims on top of the new pads that already have a thin metal piece there.
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  10. #8
    Dec 2009
    Germany/Bremen
    2,633
    Norbert
    Not the shims will turn! The pistons will turn without the old shim style!
    When rebuild 69 calipers you need also the ATE 20° angle tool to set the pistons correct in the caliper!
    So you need the old shims for correct working Calipers!!
    I don`t know if the green stuff pads will fit when you add the old shims too
    Can be to tight with new rotors!
    Btw.You can sell anything! If it work or fit is a other question
    Ooooner likes this.
  11. #9
    2,727
    Roy Bell
    4
    Ok Mr. Norbert... I see what you are talking about now. That makes complete sense. I'm going push the pistons all the way in and try to use the original shims. If that won't work, then I've got another set of new "regular" pads... I got these pads to cut down on the brake dust getting all over the wheels. Not sure what the old pads where made of but they really spit the dust all over the place....
    Thanks....
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  12. #10
    2,727
    Roy Bell
    4
    Okie dokie.... I just loaded the new "green" brake pads and used the original shims and there is enough clearance for the rotor, no problem. I compressed the pistons as far as they would go and everything fits great. I can see why the original shims are needed now. Thanks, Norbert !
    Roy Bell
    1973 Opel GT
    Carolina Opel Club
  13. #11
    Dec 2009
    Germany/Bremen
    2,633
    Norbert
    Alles wird Gut!
    Now go and eat a great dish of grit with yelly
    opelgtguy and Ooooner like this.
  14. #12
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    I don't. Why do the early pistons rotate and not the ones in the larger calipers on the 50 series cars? Granted, if I use the shims I rework the notches in the shims and make sure the pistons match the shims, but does it really matter?
  15. #13
    Dec 2009
    Germany/Bremen
    2,633
    Norbert
    I only can tell you that it is a must by ATE Caliper to install the pistons in 20° counterwise to the rotor turn direction!
    Otherwise the pads will rubbing or squeak.
    Also for the newer ones for Rekord E 246 rotors "vented or not ventend", the instruction from ATE is the same!
    Look at pictures here or read in German Language
    Bremss?ttel ?berholen
  16. #14
    Jan 2003
    Chapel Hill, TN
    7,753
    Harold Collins
    I'm not sure what y'all got in Europe but the pistons that came in the '75 50 Series cars did not have the flat spot in them that the earlier pistons had.
    P.S. If only I could read German.
  17. #15
    Dec 2009
    Germany/Bremen
    2,633
    Norbert
    Be sure the piston you show up have also the spot (recess)!
    But not in right 20° direction!
    Clean up the "drive when parket rust surface" and you will find it here
  18. #16
    Opeler 69whitegt's Avatar
    Jan 2006
    Cincinnati, Ohio
    639
    David
    I'm confused, many modern cars have screw in piston calipers as many of you probably know. My 04 RX8 is this way, I recently replaced the pads on it and neither the old pads or the new ones have notches in the metal backing plate. So even if we had screw in piston calipers with notched pads, wouldn't the notch impede the piston from functioning?
    ____________________________
    . 1972 GT " Ms. Cali "
    . 1.9 High Comp.
    . Sprint Manifold
    . 32/36 Weber
    . Isky OR-66 camshaft
    1. Question: Motor mount shim
      By 1stcarGT in forum 6A - Engine Mechanical
      Last Post: 06-10-2016, 10:53 PM
    2. rear axle shim kit obsolete...:-(
      By 73Manta72gt in forum 4A - Differential
      Last Post: 01-24-2006, 07:03 AM
    3. Torque tube shim
      By jordan in forum 4B - Propeller Shaft and Central Joint
      Last Post: 07-28-2005, 11:03 PM
    4. What is the material used for front suspension shim?
      By airbob01 in forum 3A - Front Suspension
      Last Post: 11-26-2004, 12:55 PM
