Real Name: Jon
Unanswered: 68/69 Kadett motor value?
Thanks in Advance Jon
#3 (permalink) | |
68 or 69 Opel motor
Last edited by tekenaar; 03-13-2007 at 11:02 AM. Reason: pervious post . . . ;-) |
Can you provide pics of the motor? Also on the driver's side of the motor about 1/2 way up the side of the block is the number of the block. Provide a pic of it too, as the year you're describing could be anything from a 1.1, to a rare 1.5, or a 1.9
What someone wants to spend, here in Holland something like a 1.1 would go for a few hundred euro's
Type of Motor
If it is a twin carb 1.1 litre motor the twin carbs will be single barrel sitting on the head beside the rocker cover - it is also a tiny motor.
If a 1.9 litre the twin carbs will either be side draft 2bbl ones hanging out the passenger side OR down draft 2bbl ones on a curved manifold on the passenger side. Either of the second options is a bit more exciting as that would tend to suggest the motor has been modified for hi-performance - but to find out how much would involve some disassembly. The double side draft option would be aftermarket - possibly twin DCOE Webers. The twin down draft set up is an Opel factory set-up used on Record "Sprints" and should have the "Sprint" exhaust manifold too. If there is a factory air cleaner on it the Otto would be most interested in it! The 1.9 litre motor from a Kadett will bolt straight into a GT as long as the GT engine mounting brackets, which bolt to the motor, are used. I understand that the Kadett gearbox has the gearshift levers on the opposite side to the GT though internal parts are the same. As to price - a sitting motor without FULL specs of what is in it and a cast iron guarantee of full refund/repair should anything be wrong is worth $100 - $300 tops. Get us a picture or two if you can ..... for any further advice.
That's only on the automatics, Jim, the manual trannies are a bit more complicated. As long as you use the GT shifter the Kadett manual will swap right in if you have a 1.9L. On the 1.1 you need to have the "sport" 4-speed, which has the shifter extension housing, it should drop right in. The standard Kadett 1.1 MT would have the shifter coming out behind the dash on a GT. You would also need the driveshaft and engine cradle, I think, fo the 1.1 if you were swapping it into a GT origionally equipped with a 1.9L. I couldn't even begin to tell you where you would get that driveshaft as cutting down a Kadett one would be very difficult with them not having any front u-joints or yokes.
1958 Rekord Sedan, 1958 Olympia Wagon, 1959 Opel Olympia Sedan, 1967 Kadett Coupe, 1967 Admiral Sedan 4L CIH-6, 1968 Kadett fastback 1.1L, 1970 Kadett Wagon Turbo 2.2L, 1971 Kadett Sedan 1.1L, 1975 Manta Wagon 4.3L V-6 Last edited by oldopelguy; 03-13-2007 at 08:50 PM. |
Thanks, Stephen.
I have both a GT 1.9L auto g/box and a GT 1.1L "Sports Shift" g/box but have never seen an 'ordinary' GT or Kadett 1.9L four-speed manual g/box!
BTW: As far as swapping a Kadett 1.9L motor into a 1.9L GT - Does the Kadett intake and exhaust manifold fit or does the GT (intake, in particular) need to be used due to the fact that the GT motor is tilted 14 degrees to the passenger side ? Yep! Just looked in the parts books - year for year Kadett and GT intake/exhaust manifolds are the same part number, as are some 50-serries 1900's Duh! I guess that is why "Sprint" exhaust manifolds fit straight on to GTs !!!
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 03-13-2007 at 09:05 PM. |
manifolds
Kadett and GT intake and exhaust manifolds are the same, or all the ones I have had were the same. Some of the Manta's did have a different exhaust and a taller intake, but the Kadett and GT stuff should interchange fine. Pretty much all that was changed to tilt the motor was the motor mounts, near as I can tell, and they didn't do any of that with the 1.1s.
Real Name: Jon
Well I work tonight, so if he is working I will see what he found out. For right now, alls I asked him was to get was the motor size (1.1,1.9) any mods that have been done, and whether the tranny is an auto or manual. I will let you know when I can. He said it had quite a bit of "get up and go" so that is why I am kind of doubting it was a 1.1L. A 1.9 with dual carbs should have some "get up and go" lol.
