Old 08-19-2007   #1 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Unanswered: Engine Crossmember
I need to know what the engine cross member torque settings are where the 6 bolts screw into the body "frame" and for the engine mounts themselves. There are two other bolts that screw into the side on the cross member as well.
I also need the torque settings for the four bolts on the transmission mount.
I am finally seeing the light at the end of the tunnel as I got my engine and transmission back in today!
Thanks for any information you can pass my way!
Thanks...
Roy Bell
1973 Opel GT
74 Manta Rallye
Concord, North Carolina
Carolina Opel Club
OMC
Ooooner is offline
Old 08-19-2007   #2 (permalink)
Roy, you mean torques like "just before the bolt head snaps off?"
Old 08-19-2007   #3 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Gene,
That's about what I figured but just wanted to see if there were settings. I sure could not find anything in the factory manual on it!
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 08-19-2007   #4 (permalink)
Roy;
I just went through this with Tony's GT, but, we replaced the front suspension. We just put a good hurt on the bolts.
Old 08-19-2007   #5 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
My front suspension is out right now, too. I have already rebuilt it and will be installing it back in this week. I think I saw in the book the torque setting for the front suspension to the body! I can't remember what it was right now...
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 08-20-2007   #6 (permalink)
Roy, according to my Hayne's Manual for the front suspension cross member bolts, the torque is 36 foot pounds and for the engine/tranny cross member bolts, it's 30 foot pounds.
Old 08-20-2007   #7 (permalink)
edca_opelgt's Avatar
edca_opelgt
general torque settings
Dear Opellers,
I found an interestning website where you have an idea about torque settings that can be used when you don't have the specific data.
It is in dutch but it is quiet easy to understand.
The first colum is the sort of threat (metric), 6,9; 8.8 and 10.9 is the quality of the bolt you use.
Remark that the torque settings in the diagram are maximum settings; nominal settings are 7% less.
Hope to help you out with that,
Greetings,
Eddy
http://www.onkenhout.nl/media/docume...almomenten.pdf
edca_opelgt is offline
Old 08-20-2007   #8 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Eddy, Ron and Gene,
Thanks for the information! That really helps me out. I guess I need to get a Haynes book now.
Again, thanks for your help...
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 08-20-2007   #9 (permalink)
Roy, those torque values were for the "main" bolts not the hanger strap bolts on the engine crossmember that go into the tranny tunnel. Those are smaller and would take less torque. Although they are not specified, the general torque values for a 10mm bolt (15mm head) is 30 ft. lbs., an 8mm bolt (13mm head) is 15 ft.lbs., and a 6mm bolt (10mm head) is 30 in.lbs. HTH.
Old 08-20-2007   #10 (permalink)
Gene, Roy is a school teacher I'd say he can tighten them with hand tools as tight as he wants and not worry about over torqueing them.
Old 08-20-2007   #11 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Hee Hee Hee... Harold, that one is stored in my memory bank!
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 08-20-2007   #12 (permalink)
OOOOO, that one hurt....
Old 08-20-2007   #13 (permalink)
Ooooner's Avatar
Real Name: Roy Bell
Gene,
Like I said, that one is in my memory bank. I will get him back...
Hee Hee Hee
Roy Bell
1973 Opel GT
74 Manta Rallye
Carolina Opel Club
OMC
Ooooner is offline
Old 08-20-2007   #14 (permalink)
Originally Posted by Ooooner View Post
Gene,
Hee Hee Hee
Memory bank is probably bankrupt. NOT! Wow, no hair on your butt just like I figured.
Who's yo Daddy?
About the light at the end of the tunnel thing, it's probably the train. I have to quit posting now as I'm sure I've used up my allotment of smilies.
Mod's, you won't hurt my feelings if you delete this series of "jests". Please give Oooner plenty of time to read this as he is a slow reader before deleting. IF he comes back with something really good you may go ahead and delete it immediately!
Old 08-20-2007   #15 (permalink)
Site Admin
Gary's Avatar
Real Name: Gary
The technical term is - "Half a turn before it breaks"
Gary is offline
Old 08-21-2007   #16 (permalink)
Gary, I thought the terminology was "Smoke Tight And A Quarter Turn"
That is tighten the bolt until it starts smoking, then add a quarter turn more.
Old 08-21-2007   #17 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
stars
Those bolts would be two stars tight, as in tighten until you see stars, but only two of them.
oldopelguy is offline
