Dallasmanta
Real Name: Ron
I have always used a cardboard washer made from the box the filter came in. The Easiest way is to place the cardboard on the top of the drain plug and tap along the dia of the plug thus causing the cardboard to form the exact size hole for the drain plug. Then I thread it on the drain plug and trim the outside edges with a pair of scissors. Now you have a drain plug washer that will seal out any leaks. Ron
1970-GT
I have been using a Plastic (Nylon) washer from an auto parts store.
They have radial grooves molded in to help seal. Just take your drain plug in and match the diameter under the head of the plug. Don't over tighten, 35+ year old aluminum threads! Works great. Lyle |
The original washer is just a flat round washer made out of copper. You can buy one in any hardware store.
Dieter
I replace the drain plugs on all my cars with Fumoto drain valves. Never had a problem with one and I love 15 minute oil changes with no tools required. Also, since you only have to screw it in once it doesn't wear out aluminum threads in the pan and you can use a dab of silicone on it to make sure it seals perfectly.
Since they don't list Opels on their site, what type is needed and where do you buy them?
Dieter
I usually order directly from Fumoto, they have as good a price as anyone and are pretty quick on the shipping. I can never remember what the Opel plug thread pitch is, I have to check it every time and just order by that:
QuickOilDrainValve.com - the best way to change oil
Don't know if I would recommend it on the steel oil pan Opels. I've seen similar drain type devices before but I would hesitate to use them on any pan unless the drain hole was located on the side of the sump. You would probably never hit it but... I'll bet all of OldOpelGuy's pans are AL with the drain on the side. Harold |
thats right. we use a copper ring to avoid leaking. thats usual here. they get replaced at every oil change and cost just some cents. opel still uses this rings on their cars today. i am wondering that this is not common in the us.
Honda has been using crush washers since 1990 and Saab uses them too.
#15 (permalink) | |
On a steel pan, if I was planning on off-roading or something, I would weld on a half-circle (or full circle, come to think of it) of steel to protect the valve before I would go without it.
#16 (permalink) | |
You've always heard of the person that can tear up a steel ball bearing with a rubber mallet. That's been me on a rare occasion or two. ![]() Harold |
Attachment 18075
From left to right 12mm 14mm and 16mm id. I believe the outside dia. is 13mm. for the stock drain plug. I like the rubber over alum. washer over the other ones. Last edited by wrench459; 09-01-2009 at 11:20 PM. |
Original copper washers are available in every auto parts store, where the oil cans sit. I bought a set of 3 today, size M14, for US$ 1.98 at my local Advanced Auto Parts.
Dieter
