Old 06-23-2008   #1 (permalink)
Alberta Opeler
Ray Morley's Avatar
Ray Morley is on a distinguished road
Unanswered: 1.9 Kadett and GT Motor Mounts
I plan to install my two mounts on my 70 Kadett Rallye this week as both mounts are pretty well squashed.
When I compare the two new mounts one is larger than the other.
Which one goes on the drivers side?
Ray Morley is offline
Old 06-23-2008   #2 (permalink)
Mach1Tom's Avatar
Mach1Tom is on a distinguished road
Ray, If I'm reading my factory Parts Book correctly, both mounts should be the same.
68-70.... Kadett (1.5-1.9 eng) # 684273 MOUNT (damper)eng. frt mtg
71-72.... 31-36-39 "........." # 684273 " ............................... "
~ Tom
Mach1Tom is offline
Old 06-23-2008   #3 (permalink)
opelspyder's Avatar
Engine mounts
Kinda funny, I replaced my mounts on the 70 Rallye tonight. I found the transmission mount plays an inportant part on the Kadett, so make sure it is good as well. I then simply chained the front of the engine and hoisted it up to replace the mounts. A lot easier of a job than the GT for sure. Bolt access is a little easier. The mounts are the same, and the GT carries the same number as well
Keith
opelspyder is offline
Old 06-23-2008   #4 (permalink)
West Coast GT's Avatar
West Coast GT
Originally Posted by opelspyder View Post
... A lot easier of a job than the GT for sure. Bolt access is a little easier...
Why is a GT harder? I need to replace my GT's engine and transmission mounts and haven't figured out yet how to approach it.
I was thinking of maybe using a floor jack under the engine, then dropping the cross member. Would this be the best way?
West Coast GT is offline
Old 06-24-2008   #5 (permalink)
Alberta Opeler
Ray Morley's Avatar
Here are two pics of the mounts I was sent. One is larger and has a longer stud on the top.
When I got them in the mail last fall I noticed they were different in size but I thought thats the way they should be..........a larger one for one side and a smaller one on the other side.
Otto.........help.............
Old 06-24-2008   #6 (permalink)
To be honest, it looks like you get the same part from different manufacturers. The difference is slight, but, I don't think it's going to matter much.
Old 06-24-2008   #7 (permalink)
opelspyder's Avatar
Engine mounts
The GT's mounts are a little harder to get to is all, and the car sits a little lower in the front. The mounts are on the crossmember on the Kadett, and they are slightly forward where you can with ease remove the lower bolt. In a GT they are a little harder to get to is all IMHO.
Keith
Old 06-24-2008   #8 (permalink)
Obvious!
Originally Posted by Ray Morley View Post
Here are two pics of the mounts I was sent. One is larger and has a longer stud on the top. ..
The one on the right in the first picture has an OPEL logo moulded on to it - the left hand one has not - so it is probably a 'cheapie' knock-off copy.
Guess which one is correct!
I suppose you could always put a spacer under the short one ... until you find another genuine OPEL one ......
Old 06-24-2008   #9 (permalink)
wattiefan's Avatar
Real Name: Nickolas
wattiefan is on a distinguished road
Just did the same thing on my 72 gt
While the engine was propped up, we took the crossmember down and cleaned the years of leaking old sludge off of it and the motor mounts basically fell out. Quick replacements came from ogts. We went ahead and did that while we were replacing the seal on the oil pan. It is much easier(although still a pain) to get to.
wattiefan is offline
Old 06-29-2008   #10 (permalink)
Alberta Opeler
Ray Morley's Avatar
old and new motor mounts
Thanks for the advice on my motor mount questions last week.
I had no problems at all changing them and to my surprise I discovered that when I took the old mounts out the larger one was on the drivers side and the smaller one was on the passenger side.
My main concern with my original posting was that my two new mounts were different sizes.
The old mounts were in terrible shape and much smaller in size compared to the newer ones due to age and wear. After installation the engine ran much smoother with virtually no vibration at all.
Old 06-29-2008   #11 (permalink)
Gordy's Avatar
the GT engine sits at a slight angle so it would stand to reason a smaller mount would have been on the right side where it sits lower. I believe Gil at OGTS had told me once that even the metal motor mount bracket which attaches to the engine was a little different left and right sides.
Gordy is offline
Old 06-29-2008   #12 (permalink)
Originally Posted by Gordy View Post
... the metal motor mount bracket which attaches to the engine was a little different left and right sides.
The metal brackets ARE different but I don't recall there being any difference in the actual mounts themselves. Unless it is accidental because of variations between manufacturers.
hrcollinsjr is online now
Old 06-29-2008   #13 (permalink)
opelspyder's Avatar
The Kadett mounts and the GT mounts
The mounts are different, but do not affect tilt angle. The Kadett does not tilt, but the engine mount ear on the driver's side is a lot longer, but no tilt is incorporated on that car as far as I can tell. The engine oil pan sits level and close to the front suspension cross member on those. The GT's tilt due to the engine cradle, for air cleaner clearance. All the mounts are the same, we are seeing differences due to manufacturing and extreme wear. The GT's engine mount ears are different, even in parts books. What is different, I don't know" I think hole location, but the driver's side is indicated by a small dot or indention by the mount's hole on that side.
Keith
Old 06-29-2008   #14 (permalink)
UngerDog
ungermm's Avatar
I thought the mounts on a GT tend to get squashed more on the passenger side due to them being close to the heat of the exhaust manifold.
ungermm is online now
Old 06-30-2008   #15 (permalink)
That's exactly my experience with my GT, and from Ray's photo, common to Kadetts as well
Old 06-30-2008   #16 (permalink)
Angles ...
... The GT's engine mount ears are different, even in parts books. What is different, I don't know" I think hole location, but the driver's side is indicated by a small dot or indention by the mount's hole on that side.
Keith
The diference is that one side angles up - the other down to compensate for the 7 degree angle the motor sit on with the GT. Also one has the engine mount hole further away from the motor than the other - the actual metal brackets are not interchangable from side to side.
Old 06-30-2008   #17 (permalink)
opelspyder's Avatar
Degree tilt
No if you set the engine cradle down and look at it in the frontward view, one post of the engine mount is taller than the other. I don't think the tilt is quite 7 degrees as this has been discussed. Then mount ears off the engine do not have a 7 degree tilt on one side to the other that I can see with them side to side. I think I am going to pull out all the pieces and settle it once and for all about this tilt factor. I will measure everything, and check angles on the mounts with an angle finder. And then post my information
Keith
Old 06-30-2008   #18 (permalink)
opelspyder's Avatar
A few resources to be noted
Okay, here is the engine mount for a GT. Both rubber mounts are the same. The Driver's side measures taller at 7 to 7-1/2 inches tall from the flat of the frame rail mount to the lower edge of the rubber mount. This is from where it would mount in the car. The passenger side is about 6 inches tall. That is a 1-1/2 difference. The cradle is looking from the back of the car to the front. The engine mounts have no apparent tilt than from the other ( Although I have not put an angle finder against the two. The both measure 4 inches long. The driver's side hole is right at 3 inches from the mounting point of the block, the passenger side measures 4 inches, but it's mounting hole is about 3-3/8 inch from the engine mounting flange. The drivers mount ear has a small dimple directly from the outside of the mount hole to indicate what side it is. I think this only affects centering of the engine to the chassis, like the Kadett. I do not believe it affects tilt at all. Please do not through in the fact of the shims that are located between the engine cradle mounts and the body frame rail. They are both the same thickness, and do not affect tilt. The intake is not a good point to measure tilt from, as it has been verified that Opel made different height intakes on 1.9s. I'm not sure the exact tilt yet of the engine, but if there is anything to add to this that I have overlooked, please inform us, as this is about the 10th time this has been discussed within the last year it seems. Lets lay it all out.
Keith
Old 07-01-2008   #19 (permalink)
Alberta Opeler
Ray Morley's Avatar
One thing about this forum is...............
A simple question can sure lead into a long informative thread. As long as we can all benefit from the information provided it makes this forum worth it weight in gold!
Old 07-01-2008   #20 (permalink)
opelspyder's Avatar
Answers
Yeah Ray, did you get all the info you needed? Kind of funny how these lead. I found that a lot of questions pertaining Kadetts, led to a GT discussion, because everyone assumes the car is identical underneath. They are not!!!
Keith
