Real Name: Jon
Unanswered: Found some interesting things..
![]() 2nd, does anyone see a reason why someone would cut that section of engine compartment out? It gives access to everything behind the front passenger wheel, but.. WHY? And last but not least, what is that large piece of sheet metal in the 2nd picture? There are no bolts/screws.. it seems to be spot welded into place or something. It also looks like it would have to be removed in order to drop the motor as it is connected to the engine mount/crossmember.
Current 1970 GT; Under Construction Previous 1969 GT; Street/Strip Project 1969 GT; White with Black Interior, Automatic 1969 GT; Black Parts Car 1969 GT; White Parts Car 1970 GT; Silver with Red Interior 1971 GT; Orange with Black Interior, Turbo 1972 GT; Red Parts Car 1972 GT; Blue with Black Interior 1973 GT; Pearl Blue with Black interior. Full body kit. Last edited by Sparky73; 07-25-2008 at 06:37 PM. |
#2 (permalink) | |
The hole? . . . PO inherited anomaly, who knows the reason!! Sheet metal in 2nd pic is passenger tunnel heat shield and is mounted wrong . . . also PO! . . . it should end up over that engine cradle mount pointed to the rear. It is bolted to the frame rail from underneath by a couple of screws and is normally removable once these screws are removed. Looks like PO left the heat shield installed and then installed the engine cradle over the top of it . . . wrong order!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 07-26-2008 at 02:09 PM. |
Real Name: Jon
Is that heat shield something that is rarely re-installed? Out of the 10 GT's I have owned, this is the first time I've seen one, along with the rubber boot covering the oil sending unit.
Is the hole going to cause problems? Should I attempt to fix it or just start with a new block? Maybe I'll keep saving cash and just order a 2.4 from Opel GT Source..
To add to Otto's post, the engine cradle should have a bolt through the rearward pointing "ear" to help prevent forward/rearward movement. There should be one on the other side also. "NASTY", WHO and WHY would anyone do these mods? Harold |
Looks like the dreaded PO was trying to fit a turbo.
Driver
Real Name: George
Maybe the hole was for a cold air intake? Along with mud and anything else the tire slings up/
Real Name: Jon
LOL, all great idea's guys. I also noticed.. part of the metal seems to still be attached. Like whatever caused the hole came from outside, not from the internals. It also appears there is a small tab on that piece of metal that is actually touching the flywheel. I wonder what really happened..
(BTW, if anyone remembers her, this was Heather's car from Hemlock, MI. I know some members knew her and knew the car was shipped from the South/West region.)
#9 (permalink) | |
Real Name: Jon
Yes, she did. She moved to Alaska before I even knew about the car. Her dad and I finalized everything before bringing it home.
I live right between Hemlock and Saginaw, so the car had been only 10 minutes from my house and I never even knew it. Actually, my grandparents also lived about 1/2 mile down the road from her parents house..
