Opel Forums
Go Back   Opel Forums > Technical Forums > The Main Tech Forums > Group 6 - Engine
Old 09-24-2008   #1 (permalink)
xet4 is on a distinguished road
Unanswered: Race cams(c20xe)
Hello friends,
5 months ago i installed SBD 304/295 degree 11.9mm valf lift cams
but my problem is the exhaust cam is short there is no L shape for hall sensor reading
i installed them but when i push the accelerator the car was stopping(i was using motroic 2.8 ecu and chip) and the car goes very bad(looks like 150hp )
afr on full throtle 13
on part throtle 14-14.5
i have not got taper throtle
my c/r is 12
is hall sensor can efect it?
now i am using aftermarket engine management and i dont need hall sensor(semi-sequantial and waste-spark ignition i have to use because i have not got hall sensor on my sbd cams)
is the car going to run with no problem beacuse when i use original engine management the car stoped and when i want to run i have to push throtle %30-35 and i have to push very slowly the car couldnot go nearly 3000 rpm
now i have aftermarket ecu can i use my car easily or not?
Thanks
xet4 is offline   Reply With Quote Top home
Powered by vBulletin® Version 3.7.3
