Unanswered: Engine removal gt - 2 questions
1) Is it necessary to disconnect the exhaust downpipe from the exhaust manifold or can I drop the engine with the pipes still connected.....the bolts appear to be rusted shut. 2)When you unbolt the engine crossmember, do you unbolt the engine from the crossmember first (the motor mounts) or do you drop the engine togehter with the crossmember attached (as one piece)??? Thanks
#2 (permalink) | |
Next, leave the motor BOLTED to the motor mounts and the cradle, it'll all come out as one assembly, and you can take them off when it's out from under the car.
No....its not a Buick....
Personally, I unbolt the motor from the mounts and support the engine as the added weight of the engine will make the crossmember bolts harder to remove. You have to remember, the crossmember bolts have a bolt welded inside the uni-body and the chances of breaking that weld and having that nut spin around inside the rails is a REAL PITA to get out!!! Take alll the un-necassary weight off the engine crossmember before you try and un-bolt it. You will be much better off in the long run.
JMTCW Joe
Sorry to hijack the thread but I just removed my engine and trans as an assembly. My questions is, what is the purpose of the horizontal bolts, one on each side of the engine cradle (13mm)? The one on the passenger side spun and I had to cut the head off with a dremel tool.
If what Jeff suggests doesn't work, you can always remove the nut and weld another in its place. They are both located in the footwells inside the car, alongside the tunnel up towards the firewall. HTH.
