Unanswered: Exhaust Collector Position
I have a Peugeot 504, it has 4-2-1 exhaust system, while the pipes length between the manifold flange and the collector are VERY short, about 20cm, then a single pipe to the end, traditional system. My question is, what are the effects of moving the collector, down the pipe, i mean lengthening the twin pipes before the collector, will this increase or decrease high and low rpm power/torque?? Many thanks in advance. Greetings Ahmed |
#3 (permalink) | ||
tuned exhaust
Found this on DirtracingForum
The length should be mathematically determined to maximize engine breathing but I don't know the formulas involved. Since an engine is really an air pump anything to improve breathing volume increases output. The best arrangement creates a pulse in the exhaust pipe where the low pressure behind each "puff" actually helps pull the next "breath" along & helps scaveng spent fuel out of combustion chambers. Here is an depth article covering this subject by respected exhaust guru Jack Burns. Last edited by SoYank; 04-07-2009 at 07:45 PM. Reason: Link fixed |
What I've got to know math to increase the power output of an engine.
Yep. Do you have an idea of the total airflow the engine is ingesting? With our Opels slightly modified 115 gps is not out of the question. Your going to need very detailed info on the engine. This might help HEADERDESIGN.COM - Unlock Your Engine's Potential with your endeavors. |
One thing about all the programs out there that calculate header design parameters....I've yet to see one for 4-2-1 designs. They all seem to be for 4-1 designs only. Apparently there are some variables with a 4-2-1 header design that don't calculate all too well. From what I've seen/heard, the best thing is to talk to someone who has done the development hands-on.
From my (very) limited experience with 4-2-1 designs, lengthening the secondary side moves the torque down into a lower rpm range. But I've personally never seen a 4-2-1 design that makes as nice a powerband as a well-sorted 4-1 design. I emphasize the 'well-sorted' because most 4-1 designs are far from optimal and are usually pretty horrid!
![]() Provided Answers: 10
The exhaust manifold on my GT is connected to a dual leader pipe which then tie together about 24" down stream; which we will call the collector for now. I don't know if this is what is ment by a 4-2-1 design, but the distance is the same from the manifold flange to the collector on any one of the cylinders. The inner pipe which takes car of cyls 2&3 is slightly longer than the outer pipe, which takes care of cyls 1&4.
I was originally thinking of separating the pipes and running a dual exhaust. But I believe if I do that I will improve flow but totally kill my low end torque. What would be the better way to go?
