| View Poll Results: Which way do you remove your GT engine? | |||
| Out the top |
34 | 19.32% |
| Out the bottom |
142 | 80.68% |
| Voters: 176. You may not vote on this poll | |||
#26 (permalink) |
Opel Metalhead
Safety
![]() I grew up in Iowa and my Dad and I would always work on our cars together. No earthquakes to worry about there. He had a heavy duty hydraulic jack (unlike my scrawny little guy) and used that as primary support. He was very safety-conscious, and never trusted jack stands, but used huge tree stumps with 4x4s on top of them as secondary support, usually under the bumpers. Can't do that on my GT...no tree stumps and I sure wouldn't trust the bumpers. He never had any accidents in over 50 years, but I was always nervous getting under a car or watching him. My father-in-law, who is NOT safety-conscious at all, had a car up on ramps, and somehow it fell off them when he was under it. I still don't know how he survived. His chest was sore for a couple weeks, never went to the doctor, and went right back to working on cars. I'm happy being paranoid...better safe than sorry. Especially now that I'm in California and don't have the luxury of my Dad's workshop and being able to ask his advice on things.
Scott '73 GT - Work In Progress '74 Manta - R.I.P. '75 1900 - R.I.P. |
#27 (permalink) |
Opel Metalhead
Earthquake safety
Ron, I see you live in Imperial Beach. I lived in San Diego near UCSD when I first moved to CA. The biggest quake I've felt was the one in Joshua Tree in '99 I think. Was a 7.2 I think, with serious shaking for over 30 seconds. Didn't have my car to work on then, though. It seemed to come on slowly, so I think I could've gotten out before the big shaking happened.
Now that I'm in L.A. I've felt about 4-5 small earthquakes. They were more like jolts, as if someone picked up the apartment building and tossed it sideways a couple feet. Didn't do any damage, and I wasn't working on my car at the time, but I can imagine any of those could've toppled a car off stands if not supported properly. I think I'll ask my landlord if I can build a mechanic's pit
#28 (permalink) |
4ZUA787
i once had a 2001 vw bug dieseal turbo come in saying it didnt have any power any more and nobey could figure out what the problem wus so one of the other mechanics told me to get in the car while he raised about 10 or 12 feet in the air on a lift and act like i was actually driving it and see how fast i could get it to i didnt notice but i wus in 4th gear and it wus registaring somewhere near 120 mph i was scared sh*t less that this bug wus gonna fall off the lift luckly i didnt panic to much let off the gas and slowed down the wheels very slowly and everything wus fine still didnt figure out what wus wrong with the dam thing.
#30 (permalink) |
Good question. I have never been completely pleased with the solutions I have come up with, as there doesn't seem to be an obvious spot on the Opel CIH engine to connect a chain where it properly balances the engine front to back and right to left simultaneously.
Here are a couple of pictures that illustrate my current solution, by using a spare threaded hole in the block on the passenger side and the top starter bolt on the drivers side. The standard starter bolt isn't long enough, so I found a longer bolt (M12 I believe) to allow the chain loop to be attached while the starter is in place. The passenger side is also a compromise; this location requires the removal of both manifolds and the thermostat housing. I tried to get a chain loop to fit to the exhaust manifold bolt, but it isn't long enough, and I didn't have a spare bolt that was long enough with the correct threads. Be careful about using a rocker stud to attach a lift chain. I have seen a few studs stripped and/or bent by doing just that. Any other suggestions?
#32 (permalink) |
Go to a junk yard and get some of those GM block "eye" pads. I've found the having 4 or 5 of those around the garage is mighty handy. Unless you have a friend in a shop who can lift the body while you have a tranny jack (or other) under the motor.
my 2c's |
#35 (permalink) |
I kinda got to this thread late, but here's my input. Keith is correct is using the starter bolt and the spare threaded holes on the passenger front side of the block, and yeas you can leave all engine accessories on the engine to remove it out the bottom of the car. BUT, use a floor jack under the tranny to help balance the assembly front to rear while dropping the engine.
Ken, the eye pads are common on almost all engines, including foreign cars. They are the stamped steel plates with large holes in them the factory uses to initially install the engines on the production lines. It takes too long to remove them, so they leave them in place. On my V-6 there is one front driver's side and rear pax side. Ron |
#37 (permalink) |
if you have "extra" parts...
On my wagon, which has much easier access than a GT, I took 2 of the rear cam covers and welded "eyes" to them that go straight up. The rear one can be installed "inside" the lip on the front one with longer bolts, so I now have hook-up points front and rear on my motor. The front eye has my fuel pressure regulator mounted to it normally, and the rear mounts the heater control valve, so unless you really look you can't even tell they don't belong there.
#38 (permalink) |
...so can I put the engine in with the alternator and distributor attached (as your picture indicates)?
Sorry to disagree with Ron, but it is mandatory (at least by the FSM) to remove the alternator. It is also HIGHLY recommended to remove the distributor when lowering or installing the engine in a GT. Not only does it go in/come out easier, but you won't risk damaging either in the process. I have the alternator and distributor installed to keep junk from falling into the engine and because I installed a new alternator bushing set and shimmed the upper mounting hole and wanted to check it out before I installed the engine. You also have to remove at least the carburetor. I prefer to also remove the intake and exhaust manifolds. JM2CW, IMNSHO
#39 (permalink) |
Keith, you're probaly right about the alternator, I took off the AC compressor, brackets and belts before I dropped the 1.9 out of my GT, so probably the alternator came off too. I just looked at my project pics again and I had the alternator and both manifolds off when I dropped the engine. The starter and distributor were still on the engine. I wasn't going to use the engine again in that car, so I took off minimal stuff to expediate the removal.
Ron |
#40 (permalink) |
Engine out easy.....
After recent discussions on here, yesterday I went with the bottom out method of removing my engine (with trans. attached) using an engine hoist and floor jack. It went MUCH easier than I expected. Thanks for the advice.
#41 (permalink) |
Opel fan
I never tried pulling a GT engine from the top before. Before this past summer, I had a GT engine out 3-4 times from the bottom. So far this summer/ fall, I scrapped 4 Gts and disassembled them down to practically nothing left. I found out how easy the front suspension comes off and how easy the engine drops down with the f/s gone. No more prying the engine back to clear the crank pulley and lower the engine at the same time. It just lowers nice and easy to a wheeled dolly and since the front tires, along with the whole front suspension, are gone, I don't have to raise the car up so high. It also makes detailing or restoring the front suspension easier.
Jim B. |
#44 (permalink) |
was it necessary to take the valve cover off to pull the engine?
It looks like the car was high enough that the valve cover could have stayed on. But the lifting chain often interferes with the valve cover, if you use the top starter bolt and the hole in the block on the manifold side. And you also have to remove the thermostat housing, as the diagonal chain will ride against it, and it's only aluminum and might break. I like the earlier suggestion to make lifting lugs that are welded permanently to the cam cover plates, as it would provide a nice straight lift to the engine, and then you could use a lifting bar to balance it front to back. But I think I would want to use stronger grade (10.9) bolts, as the cam covers are only held in place with M6 bolts, even if there are three of them on each cover. If you lift the front end 24 inches (at the jack points) and the rear 22 inches, you should have enough clearance to even leave the mounting cross member in place, and lower and remove the engine and cross member together. Then the engine can be slid out on the cross member, rather than the oil pan. Or do what I did, and make a little flat dolly (available from Sears for making saw table and drill presses mobile) that you lower the engine on to, and then it is much easier it work on. Until you get a proper engine stand, which Santa brought to our house just before Christmas. JM2CW
#45 (permalink) |
I thought I'd have to put a longer bolt in the top starter bolt hole (as a place to hook the chain) but couldnt get the one I had in because the head came back too close to the housing and I couldnt get a wrench on it. Instead I took the starter off and then felt safe using the bolt that was in there already. I have to get the right length bolt because I don't want to mess with the starter with the engine in the car ever again.
#46 (permalink) |
To think, it was exactly a year ago I asked the question, just how are you supposed to get the engine out?
Started a war, remember? I've learned a lot in the last year (about GTs, anyway). In my car, it comes out the top real easy now that the cowl is gone, there is no radiator bulkhead, or brake system in the way. Only from a distance is it recognizable as a GT. Regardless, from its last mockup removal the engine/trans assembly together did come out slick as a whistle From The Bottom and two guys easily lifted the car up and over the assembly. I bet two really big guys could do the same with a completely stock GT.
#48 (permalink) |
Speedway GT hangs by bungee cords from hooks screwed into the ceiling of the garage. See it in the thread "show us your garage".
I know, it's strange. But it works. A bungee cord will pull about 30 pounds, ten of them pull 300 pounds, etc. They are hooked to just about anything on the car. Keep in mind the body is completely off, and the chassis is a skeleton of rollcage tubing. It's a circle track race car, you see, built like NASCAR rigs only a little smaller... When it was stock, as I recall, we lifted the front with the boom truck, the chain hooked under the lip of the front crossmember just next to the spring. With the motor mount, trans mount, etc. unbolted from the body and sitting on the ground, the front of the car can't weigh but about 500 pounds. I'm guessing. Heck, five guys then picked up the whole car and set it on the chassis jig. That was with all four tires on still. Here's a picture, sorry it doesn't show what you are really wanting, it was a joke to make it look like Steve is holding the car up with his back... we had just dragged the engine/trans assembly out from under.
No Opels were harmed in the filming of this movie. However two Mustangs, a Pinto, and a Capri were hospitalized. One Mustang was euthanized the next morning. Last edited by jeff denton; 11-19-2007 at 01:31 AM. |
#49 (permalink) |
bear,
I bolted the chain to the upper bolt of the starter (using just a slightly larger bolt to make up for some of the thickness of the chain) and the other end to an unused threaded hole just above and slightly to the left (towards the rear of the engine) of where the grounding strap attaches. Hope this helps. |
#50 (permalink) |
I own 5 of these little rascals I've pulled engines top and bottom. After it is all said and done, the bottom is the way to go. Not only is it faster it also is safer IMHO. I've really made a mess of the engine compartment paint thinking the top was easier. For the top removal, removing those bellhousing bolts while it is in the car hope you have patience and endurance.
