| View Poll Results: Which way do you remove your GT engine? | |||
| Out the top |
34 | 19.32% |
| Out the bottom |
142 | 80.68% |
| Voters: 176. You may not vote on this poll | |||
#101 (permalink) |
#102 (permalink) |
well i have the new gt at my house...no garage, jacks, hoist, chain, or tree...thinking i may just undo everything and get a 10' 4x4 and put eyehooks through it and attach to the motor with a chain...remove the hood, and have alot of my buddies help me lift it up and out...
Adam |
#103 (permalink) |
Adam, that may work if you can get them to stand on each others shoulders.
The engine has to come up quite a bit to clear the fenders or the sheetmetal in front of the hood. Best bet is to rent the equipment you think you'll need, gotta do it safely with the correct tools.
#104 (permalink) |
Adam, congrats on the new GT! Drop it out the bottom, it is far easier. Go get some GOOD jack stands though, you will need them!
Steve "ever notice you are never done tinkering with the GT?" Never mind, I am WAAAY beyond tinkering now...[/SIGPIC] |
#105 (permalink) |
Check this out if you wanna see scary. This is how the V-6/T-5 goes in Willit? I figured I'd put it here under this topic because it fits. You'll note I've got an incline to work on, that's make moving the hoist a bit testier, so I've got ratchet straps anchored to the garage frame and the hoist. Nothing moves until I want it to. Also there is a 4 ton hoist and a heavy capacity floor jack. Scary for sure, getting the package that high, but it's just high enuff to clear the car. All four wheels are on the ground, so there's no worries about getting things moved off jack stands. All I do is position the engine over the hole, let it down so the tailshaft is on the floor jack, then let it down some more and the floor jack rolls back as the engine drops in. It's really neat, and almost lines up with the mounting holes for the crossmembers. It should be all bolted in today, and then ready for all the peripherals to be installed.
#106 (permalink) | |
Copyright İ 2003-2009 barry williams All Rights Reserved save praying to God for sunday today we pray to Nike and run like hell |
#109 (permalink) |
That would have been neat Rick, sorry I didn't think of it. Now guess what would have been added to that if something broke on the hoist, log chain, or the one 10.9 grade bolt in the head snapped.
I'm sure glad I do these things when Margaret isn't around. She saw the pic and asked if I did it all by myself after the package was installed. I told her it was easy, all I had to have was a good mechanical advantage over the weight of the engine/tranny, plus overkill on the capacities.
#110 (permalink) |
Removed from bottom
I just finished an engine swap by the "out the botom" method. I dropped both the tranny and engine together, and reinstalled the same way. The engine was "half bare" - removed carb, starter, alternator, oil filter, water pump and radiator.
I first put the car up on rollup ramps (10 inches or so) and disconnected everything except the engine cross member and tranny crossmember. I then attached a chain to the alternator bracket to block bolt as a stabilizer. The main chain was bolted to the top starter bolt, and its other end attached using a j-hook through the engine to bell housing brace on the passenger side. This setup allowed me to hang the drive train perfectly level. Then I cut ten 22 inch peices of 3/4 inch PVC pipe, laid 5 down under the car, and laid a 20 inch by 4 foot piece of heavy plywood on it. This setup easily rolls. The motor mount top bolts were then loosened and the engine hoisted up to relieve the weight. The motor cross menber and tranny cross member were unbolted and the whole shebang was set down on the plywood. The hoist was then used to lift the car up 20 inches more by a chain around the steering crossmember, and two large landscaping blockes added to the support under each front tire. The hoist was removed and the engine rolled out from under the car, using the additional PVC pipe as rollers. The car was immediately lifted again and set back down on the rollup ramps. Note that I never had to get under the car while it was higher than a set of rollup ramps. Installation was just a reversal of the same process. Two goodies came out of this: Found a way to get the engine out from under without a comealong and didnt need 6 more inches (or more) for an engine dolly. The plywood on PVC pipe rolled almost too easily, as I had to put a chock in front of it to keep the engine from rolling away on its own. The rolling board only added about 1.5 inches to the height. |
#111 (permalink) | |
Very cool .........any pics?
Paul "azopelnut" Heebink 1956 Studebaker Power Hawk 259 V8 1970 GT 12A-Rotary 5-speed 1972 GT 2.0, 5-speed 1973 (2) GTs, both 1.9 4-speed 1973 Ascona 4-door 1.9 4-speed A/C 1974 Manta, 1.9 Auto A/C 1975 Sportwagon 1.9 FI 4-speed A/C 1975 Fiat X19 Last edited by Gary; 05-31-2006 at 07:24 AM. |
#112 (permalink) |
Brilliant! I have always had the issue with raising the car so uch higher to clear the engine on a stand. I originally built a cradle out of 2x4 that supported it under the 2 engine mounts and under the end of the tranny. Then I just shove it out, sliding the 2x4 cradle along the cement. Your system takes it one step further by putting it on rollers. I will try to draw up an even better combo taking the best of both into consideration.
Your pictures would be great to see. Thanks for sharing.
#113 (permalink) |
We did an engine removal a little over a week ago. Instead of PVC, we use 2 mechanic's creepers. Rolled right out + we had castors on the creeper so we could roll it in any direction
#114 (permalink) |
Do you just lay it on the plywood or creeper? Or do you stand it up and hold it by hand? I have always kept the engine vertical thruout, but I guess it could be layed down.
#115 (permalink) |
We put cardboard on the creepers so they wouldn't get dirty since we were going to use them. The engine/auto trans was horizontal, but we removed the head prior to dropping it. Gave us some more wiggle room. HTH
#116 (permalink) |
Kept the engine upright
Although I considered laying the engine on its side for clearence (only 14 inches on the side), I ended up keeping it upright (about 24 inches). This was mostly because I didnt think I would have room to lay it over until I lifted the car all the way up, and really didnt want to get under the car while it was in this position.
Besides, once the car was high enough to lay the engine over, it was high enough to roll the engine out. My wife took some photos, and Ill post them when I can. |
#117 (permalink) |
Sorry for the confusion. Our was still vertical(normal position). I thought you meant the crank was vertical in relation to the ground, similiar to when you take it out the top. Sorry for the confusion.
#119 (permalink) |
That could re-open a can of worms. So let me say this, I've done it both ways. The head and tranny have to be removed from the engine to pull it out the top, or put it back in. The whole package (engine/tranny) can be dropped out the bottom together or installed. There are some who have said they can remove and install a package in one day. That is remove the old package and install a new package. It is a matter of preference, The manual suggests taking the whole package out from the bottom. I took mine down and out with just a floor jack and cherry picker. For more opinions, use the search button and you'll get a lot of how to's. HTH.
#120 (permalink) | |
Happy reading. But PLEASE don't start this discussion again
Keith Wilford working on my '71 GT and '75 SportWagon Last edited by soybean; 12-13-2006 at 10:03 AM. Reason: moved to proper thread |
#121 (permalink) | |
Remove from top in GT
#122 (permalink) | |
#123 (permalink) | |
Ron, where do you hook cherry picker? |
#124 (permalink) |
P. J. if you're asking how I lift the car with the cherry picker, I use a pair of 1000 lb straps wrapped around the front suspension, and hooked up to the cherry picker at its lowest point and just jack up the car. HTH.
