Old 11-10-2005   #1 (permalink)
asdasc's Avatar
Unanswered: Help to ID 1.9L Block and dipstick hole location
Hi All,
In checking out the GT on the highway for the first time after aquiring it, I found something strange. I have 2 dipstick tube holes, one in the oilpan with a tube sticking up that is currently used for the dipstick, and one in the block just above it that had been plugged with a chunk of wood. The plug blew out at about 90MPH (it was running pretty well!) and then it blew most of the oil out of the crankcase, all over the left rear side of the engine compartment. What a mess!
I made emercengy repairs with a cork for ACE hardware, but I am afraid it won't stay due to the crankcase pressure at speed. Any ideas on how to more permenantly block it?
Also, what was stock for the GT? I *think* my previous 70 GT's had it coming up from the oilpan. Any info on the origin of this engine would be usefull. If you need pictures to fully understand what I am saying, let me know and I will post some.
Thanks!
Steve
asdasc is offline
Old 11-10-2005   #2 (permalink)
Jonzo's Avatar
Jonzo is on a distinguished road
asdasc,
If your GT is a 1970 it should have originally had an aluminum oil pan with the dipstick tube coming out of the pan as you have described. Later years had the dipstick tube coming out of the block as you described. But you're not supposed to have both at the same time!
Your block should have a steel oil pan to match it. I believe the oil pans use different kinds of oil return tubes as well and I've heard that it is important that the appropriate pickup is used with each pan.
Lastly I am pretty certain that Opel did not use any wooden parts on its engines (not counting cork gaskets)!
-Jonzo
Jonzo is offline
Old 11-10-2005   #3 (permalink)
asdasc's Avatar
The chunk of wood was definItely NOT stock! I had assumed it was wedged in there pretty well, but then it blew out the first time I got it over 50MPH.
I have the Al pan, and no idea about the oil pickup.
Oddly, the Block ID number has the * before and after, which means it is a higher compression early engine, right?
I am thinking maybe it is a block out of an earlier Manta or something?
Steve
asdasc is offline
Old 11-10-2005   #4 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
rubber plug
Most of the 1.9 motors had the hole drilled there on the driver's side, even if they were in a Kadett or GT with the dipstick in the pan. Usually it's pluged with a rubber plug that went in before the paint and has been painted over.
I usually get one of the little rubber threaded inserts (they look just like boat drain plugs) from the hardware store. Not sure what the real name for them is, but they are used for mounting stuff in blind holes, you drill the hole, drop them in, then poke the bolt through what you're mounting into the insert and tighten. The rubber expands and fills the hole and won't come out.
There might be a bigger issue with that much crankcase pressure. Do a search on that and you'll get some interesting info too.
oldopelguy is offline
Old 11-11-2005   #5 (permalink)
I have a couple blocks I wonder about, too. Both seem to be the "thick web" mains, one has a dipstick hole and the other has two. They have way different markings cast into them. I'll get some pictures up here soon. One of them will be the new race car engine...
jeff denton is offline
Old 11-11-2005   #6 (permalink)
opelwasp's Avatar
OGTS has a aluminum plug that will fill the block hole very well. only a couple of bucks i think. just use a socketextention and a hammer and presto, permanent fix.
opelwasp is offline
Old 11-11-2005   #7 (permalink)
asdasc's Avatar
Hi everyone, thanks for all the info and ideas. I was also thinking that a boat plug sort of arrangement would work well but didn't think they were available in different sizes. I will try that idea first and if I can't find it, I will get the plug thru OGTS.
Jeff, your comments got me thinking (alot). What do you mean by the thick web mains? Since I am the 100th owner of this car, and everyone has made undocumented changes to it, I have little idea about what is truly in there. I have what appears to be a new 2.0 head with an Isky cam, but the PO who added that didn't do the lower half, and thought it was LC when he had the head off. Contrast that with the block number which says it is HC. I need to pull a plug and see if I can see in the whole enough o see the piston tops this weekend.
I also have a spare short block that I was going to rebuild over the winter to drop in. I don't have it picked up yet, it was in a shed at the PO house and is still there, so I don't know what it looks like.
From what you are saying, maybe if this block is 'thick webbed' that I should rebuild this one instead?
Steve
asdasc is offline
Old 11-11-2005   #8 (permalink)
Strong!
Originally Posted by asdasc
What do you mean by the thick web mains? From what you are saying, maybe if this block is 'thick webbed' that I should rebuild this one instead?
On some Opel blocks the main bearing webs and caps are slightly wider than others. Great for the extra margin of strength for high reving race motors and/or turbocharged motors. However, for a street motor, any Opel block has a very strong botton end and there are very few problems "down there". Just check carefully for any cracks or bad damage that may compromise strength.
Pay particular attention to the head bolt threads and the main bearing tunnels
as head bolts do pull threads out occasionally and bearings do spin in the cap if too loose.
Some Opel blocks have two oil dipstick holes in them! I guess Opel just made blocks that would fit any application and plugged the holes not used.
Found the pics of the main caps - not onthis site but on TGSI's - thanks for the use of them ......
Old 11-11-2005   #9 (permalink)
Somewhere on this site are some photos from TGSI Racing that show the difference between the thick mains webs and the thinner ones. A search for "main+webs" should pop it up.
Old 11-11-2005   #10 (permalink)
asdasc's Avatar
Great pictures! Now I know what to look for. I will try to pull the oilpan on both engines and see what I have.
The goal is to have a good strong street motor that really pulls, but that is reliable to drive on the highway or around town. I want to be able to drop the pedel get the tires to spin in first or second gear. I am using the stock wheels (I like the look of them) with 185 tires.
Steve
asdasc is offline
Old 11-14-2005   #11 (permalink)
asdasc's Avatar
Photo of Blocks
This is a photo (hopefully, I haven't tried attachements yet!) of my block with the PLUG in it. I also have some pictures of the other block I plan to rebuild this winter. It does NOT have the plug in it. I am still curious what cars had the dipstick in the block, versus which ones did not have them. I will post the other pictures in a minute.
Lastly, it looks like the other block has the thick webs, so that is good. Although the only bearing cap still in place is the thrust bearing, I think. The PO still needs to find the box of parts he took off the block.
Steve
Last edited by kwilford; 11-14-2005 at 02:11 AM. Reason: replaced .bmp photo file with .jpeg format
asdasc is offline
Old 11-14-2005   #12 (permalink)
asdasc's Avatar
After looking at my pictures, getting them ready to post, I think I see the dipstick hole in the block that I was sure wasn't there when looking at it in person. Pictures are here, but I am going to go get the block and bring it home this week to be sure. I don't have room for it anywhere, but I guess I will figure that out later!
Steve
Last edited by kwilford; 11-14-2005 at 02:13 AM. Reason: replaced .bmp photo file with .jpeg format
asdasc is offline
Old 11-14-2005   #13 (permalink)
This is a photo (hopefully, I haven't tried attachments yet!) of my block with the PLUG in it.
If you can, please save and attach photos as .jpeg, .jpg, or .gif type files. The ones you attached were .bmp files, which are "bitmap" format. That format uses a lot of memory, relative to a similar photo in .jpeg. Almost ten times larger, in fact, as the .bmp files were about 200 kB each, compared to about 30 kB for the .jpeg.
Also, with the .jpeg format (or the others I mentioned), you can save them in higher resolution, up to 600 X 600 pixels, versus the 320 X 215 that the .bmp files were in. The higher resolution makes them much easier to see.
If you need image editing software, we have a program on the download page http://www.opelgt.com/forums/local_l...p?action=links called Irfanview that works quite well.
Old 11-14-2005   #14 (permalink)
asdasc's Avatar
Thanks Keith! You can delete these two posts from the thread to keep it cleaner. I did use the Irfanview to get those pictures down to size, but didn't notice it had changed the format to .bmp, I will be more careful with it in the future. Are those pictures OK or should I edit the posts and resend the pictures?
Steve
asdasc is offline
Old 11-14-2005   #15 (permalink)
I think that they are fine.
Old 05-30-2007   #16 (permalink)
Curve Crazy GT
coolchrisp's Avatar
coolchrisp is on a distinguished road
Does any one know what years had the Hole in the block, and what years had the tube out of the pan for the dipstick?
thanks
chris
Owned Cars:
1973 Opel GT
1980 Chevy Monte Carlo-Current 383 project drag car.
1972 Chevy Monte Carlo
2005 Dodge Ram 1500
coolchrisp is offline
Old 05-31-2007   #17 (permalink)
Curve Crazy GT
coolchrisp's Avatar
anybody know? yes, no,mabey so?
thanks
chris
Owned Cars:
1973 Opel GT
2005 Dodge Ram 1500
Old 06-01-2007   #18 (permalink)
SpringGT's Avatar
My '73 GT has two dipstick holes in the drivers side of the block, about 3-4 inches apart, and the dipstick is in the one closest to the firewall. The front hole is plugged with a plastic plug and some sealant. It has been this way since new.
SpringGT is offline
Old 06-01-2007   #19 (permalink)
Sorry Chris, I can't help you, I don't use dipsticks or Opel pans. I plug dipstick holes with a blob of Right Stuff.
Old 06-01-2007   #20 (permalink)
No Access
The question is kinda missleading. The answer has almost nothing to do with year of manufacture. Try what models used the Ali pan and which used the steel. They varied from year to year but by and large the Mantas and wagons had a dipstick in the block and most year GTs didn't. Early GTs had the dipstick in the block and some of the rally equipped eary mantas and 1900s had better pans than stock and different dip stick locations. Given the simple fact that so many original motors have been changed you might want to just stick with not mixing them without dealing with dip stick issues. However mixing and making it all work is common so that muddies the water even further. Confused yet?
nobody is offline
Old 06-01-2007   #21 (permalink)
Supercharged 2.4
Gumby's Avatar
That is interesting because my 72 GT (original engine) has the dipstick coming out of the engine block...
Gumby is offline
Old 06-01-2007   #22 (permalink)
No Access
Ok
69 GT steel pan with it in the block
71 GT with it in the pan
72 GT with it in the pan
73 Manta in the block
74 Manta in the block
2 73 GT in the block
1 73 wagon in the block
1 74 wagon in the pan
75 Manta in the block
Even the rally version pans differed so if you can get a firm idea of which got what, more power to ya. That list of known original motors I pulled myself and there was no clear picture of what would be there until you had it on the bench. Good luck
nobody is offline
Old 06-01-2007   #23 (permalink)
Curve Crazy GT
coolchrisp's Avatar
Yes i am VERY confused, haha. My block is stamped a 1971 date, and it has the dipstick in the block, and i have a steel pan of course... Very strange indeed.
This isnt really a urgent question, i just wanted to learn about the diffrent dipsticks is all.
Bust that list helps, thanks
thanks
chris
Owned Cars:
1973 Opel GT
2005 Dodge Ram 1500
