#26 (permalink) | |
OECS pulley?
I believe this is an air pump pulley since we're all in agreement about the A/C pulley. Harold |
#27 (permalink) | |
4246 Post Club
'Nother Idea ....
Unless you want a "stealth" pump ...
#28 (permalink) | |
Crankcase venting
#29 (permalink) | |
#30 (permalink) |
So a double pulley with a smaller rear is for an air pump, and a pulley with both grooves the same size is for A/C. On an A/C car the A/C pump was driven from the rear and alt and w/p off the front. How were the alt and w/p spaced foward? 1/4 spacers under the respsctive pulleys? Thanks
DAN |
#31 (permalink) | |
A/C crank pulley: the smaller REAR pulley is the same diameter as a stock single crank pulley and the WP and alt are driven by that rear pulley. The larger front pulley ONLY drives the compressor, typically with an idler for belt adjustment. A 1/2" spacer is used on the WP between its pulley and the fan blade to space the fan forward for compressor clutch and crank pulley clearance. Crank/WP/alt belt path is UNCHANGED from stock non A/C! Air pump crank pulley (only used on '68 engines): larger front pulley is the same size as stock single crank pulley and drives both WP and alt. Smaller than stock rear pulley drives air pump on passenger side. WP/alt belt path is moved forward by ~1/4" vs. single pulley belt path and spacers are used at the waterpump and alternator drive pulleys. |
#32 (permalink) |
Pulleys
Otto,
I have both, or more correctly three different versions of the crank pulley. There is large front with small rear pulley. This appears to be made of stamped steel. The second version is a standard size rear pulley with a slightly larger front pulley. This unit appears to be machined from a casting. A third version that I have is a cast unit with a standard size front pulley and a slightly smaller rear. Is it possible I have the GM A/C pulley, an Opel OECS pulley and an ARA pulley? I'll try to get them all out and arrayed for a photo. Dave P.S. Still got those oil filters for me? |
#34 (permalink) |
Yes, thanks for the info!
Just what I needed! I have carefully printed it out for my book of Opel knowledge.
"Enjoy The Ride!" 1969 GT, 1973 GT "Quazar" 1995 Camaro Z28 New Birthday presents for daughters: 1970 GT, 1971 GT |
#35 (permalink) | |
Yep, come by and get them any time, Dave. |
#36 (permalink) | |
Haven't seen the stamped-steel dual pulley you described before. Maybe post-'75 Euro pulley? Got me curious now . . . definitely post pics! |
#37 (permalink) | |
An update on the progress of Kats 70GT: Originally we thought the engine was frozen, the good news is that we got it to turn several times by turning the ignition. The bad news is that the emergency blinkers won't turn off, and there is a lot of things to re-assemble, like the,radiator,water pump, weber, (Thanks Tim for the rebuild!), before we can actually feel good about putting the gas in the car to give it a good try. (Andrew got sucked into working at Media Play too) The good news is tho: All Recluse Spiders are dead now! That one thing sure makes it a lot easier to work on the GT! (Or want too)!
#39 (permalink) | |
Please leave me a PM, let me know how much you want for it OK.
