bobaboueyite
Unanswered: leaking gas from cyl 3-4 with stock manifold and Header
sounds like you have an uneven pinch between the inlet and exhaust flanges
if the inlet is smaller then it will not tighten properly and you get a small leak
Someone, somewhere wrote a good way to stop leaks on header gaskets and it seems to hold true. the tip was to soak the gasket in water and install it wet. When it dried, it would conform to all the irregularities of the header flange.
JMTCW, Gene
Header Seal
I see you list stock (intake?) manifold and header.
The usual problem is that the header flange is made from "inch" thickness steel and is a different thickness to the machined areas on the stock intake where the washers contact. This is 12mm thick, on stock manifils, and often header flanges are only 3/8" thick. This makes a 'step' there that means the header flange is not properly clamped. So check that the thickness is the same. Add weld-on half-washers if necessary to get both bits the same thickness where the washers under the manifold bolts clamp.
bobaboueyite
Im not leaking from the header though. I solved that problem of the thickness with washers that clap on the intake and exhaust that were oversized to fix that. My concern is my intake flooded with gasthat pooled then. and washed out on the intake side. from what you said, it would be that the header isnt tight, but the manifold would be.
BTW, did you ever try getting the EFI manifold I sent you together? Bob |
bobaboueyite
yeah i have the manifold together, and the megasquirt is in as well. I have not installed them yet though. I did not weld the bungs for the fuel injectors, instead i am using the plastic plates. I have the TP sesnor, o2 sensor, and map sensor. Intake temp sensor did not spike when the megasquirt tried to find it.
I need the timing in order first before the FI goes on though, so i have to use the carb in the meantime, ANy suggestions? |
