Old 04-04-2006   #1 (permalink)
Jeff Pozorski's Avatar
Jeff Pozorski
Unanswered: Dual Oil Pressure Sending units?
I am in the process of adding the rallye guage package to my '73 Manta. I realize I need a special oil pressure sending unit to operate the oil guage. My question is: can I put in a T-fitting to use both the idiot light, and the new guage, sending units at the same time? I have searched the forums but kept getting zero matches. Don't know if it is possible, seems possible, but figure the experts out there would know. I like the idea of having two ways to monitor the oil pressure if it can be done.
Opelerjeff
Jeff Pozorski is offline
Old 04-04-2006   #2 (permalink)
Gauge/light OP sender
Hmmmm, something strange going on here. I searched on "OP sender" and got more than 5 pages of threads . . .
My reply to one of them from a year and a half ago should answer all your questions.
Old 04-04-2006   #3 (permalink)
Jeff Pozorski
I searched "dual oil pressure sending units" and got no matches. I thought that was funny also as I should have matched the "oil pressure sending unit" part at least. I will go back and search using the "op sender".
Thanks Otto!
Opelerjeff
Old 04-04-2006   #4 (permalink)
Jeff Pozorski
That answers my question perfectly
I searched originally using the "advanced search" option. Wonder if that made a difference because it didn't match all my key words at the same time?
Opelerjeff
Old 04-04-2006   #5 (permalink)
Don't think so . . . most of mine came back with just the 'sender' keyword highlighted.
Old 04-14-2006   #6 (permalink)
timemachine's Avatar
Real Name: Jim
Provided Answers: 7
Oil pressure sender for Manta
I have the same issue as Jeff, I want to put a rallye gauge package on my Manta. But, somebody told me the senders for Manta and GT are different: the GT measures in bars, the manta in PSI. So, he figures the senders are not interchangable. I might be able to look up the part numbers somewhere to be sure. egauges meanwhile says the senders work for both 5bar and 0-80 PSI. http://www.egauges.com/vdo_send.asp?...Bar_VDO&Cart=1 DOES ANYBODY KNOW THE CORRECT THREAD??
If they're not the same, I'm guessing you could put a shunt (resistor) across the GT sender to compensate, but with no baseline measurement, this would be guesswork.
Does anybody out there have a spare Manta/sportwagon sending unit?
As mentioned, the alternative would be a mechanical gauge. I will look for something from VDO of similar size, don't know yet if it exists.
As opposed to the T-adaptor, once I get the pressure guage set up I'll probably just disconnect the idiot light (unplugging it effectively does that). The reason is, when my old rallye engine was failing 18 years ago, the idiot light didn't even come on until the oil pressure guage was reading virtually nil, making it a post-idiot light.
-Jim
'74 Manta ("Sig")
'75 Sportwagon (project)
'72 GT (whenever I get to it)
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
timemachine is offline
Old 04-14-2006   #7 (permalink)
Jim
I have two spare ones, I cannot vouch for the working condition, but, both came off Mantas.
Gene
Old 04-14-2006   #8 (permalink)
Real Name: Jim
Provided Answers: 7
Gene,
They'd have to come off a car with rallye gauges (Manta Rallye/sportwagon)
Thanks. Jim
'74 Manta ("Sig")
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
Old 04-14-2006   #9 (permalink)
Jim;
Yes I know, I have been making Wagons and Mantas into clone Rallyes and Sportwagons for years. I know what you're talking about.
Old 04-14-2006   #10 (permalink)
14mm x 1.5 pitch PIPE thread.
Old 04-14-2006   #11 (permalink)
Exclamation Search "OP sender"!!!!!
If they're not the same, I'm . . .
As mentioned, . . .
-Jim
Hmmm, second time in less than a week in two threads . . . ANYBODY think of using Search?!!!
1.9 engine uses the SAME dual OP sender (9279853) regardless of model!! Answered aftermarket VDO source particulars 1.5 years ago citing info from 2.5 years ago.
Old 04-14-2006   #12 (permalink)
Real Name: Jim
Provided Answers: 7
well, I guess my search language wasn't right on. No need to get all teutonic on me. Thanks for the info though, at least somebody wants to know.
Also, the bushing part# mentioned in the other thread (R7965) converts - 1/8 NPT female x M18 X 1.5 male according to the egauge site. If it's M14, the part number would be R7963.
I'm going to assume the other thread page referred to M14 as Bob says unless somebody has to straighten me out again.
Thanks Otto, Gene, Bob (and Tom C.). -Jim
'74 Manta ("Sig")
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
Old 04-15-2006   #13 (permalink)
Arrow P/N corrected
Not to belabor the "Search" issue unduely, but just "sender" would have gotten you there.
Correct! . . . corrected P/N error in my original quote . . .
Old 04-15-2006   #14 (permalink)
David McCollam
Oil Pressure sender and gauge.
The oil pressure sender and gauge can be found at egauges.com. They have several VDO sending units. You can order a new one there. It's peanuts and you have the correct gauge and sender. No guess work.
David McCollam is offline
Old 04-15-2006   #15 (permalink)
Like I said, I have a sender unit sitting on my desk, if interested.
Old 04-15-2006   #16 (permalink)
gtjames's Avatar
gtjames is on a distinguished road
using a tee
Timemachine,
I used a tee like you are describing. I used the stock oil sending unit with an aftermarket gauge. It was in a 1.9 that I used to race with and it worked fine. I had numerous other problems (not relating to the sending unit), but at least the gauge worked. HTH.
James.
Don't believe everything you think.
gtjames is offline
Old 04-16-2006   #17 (permalink)
Real Name: Jim
Provided Answers: 7
Gene,
I'm going with a new sender just for the guarantee. Since you seem to have done a number of converts however, would you happen to have a fog/driving light switch for the Manta? Relay would be nice too. I also need a hazard light switch button for the steering column.
Thanks everybody else for the help.
Jim
'74 Manta ("Sig")
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
Old 04-16-2006   #18 (permalink)
Gene,
Jim
Jim;
My last fog switch just went out to WI. They pop up on the German Ebay a lot, that's where I get them. The relay, unless you want one for "correctness" you can get a solid state one from Radio Shack. As for the red hazard button, good luck, those are as rare as hen's teeth.
Old 04-17-2006   #19 (permalink)
Real Name: Jim
Provided Answers: 7
Gene,
Thanks, I will look at German e-bay, will just have to figure out what "switch" looks like in German.
Jim
'74 Manta ("Sig")
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
Old 04-17-2006   #20 (permalink)
David McCollam
Fog light switch
It German I believe it is a schaltenhabel. Then again, I've got a few of them as well. Switches, relays, Hazard flasher buttons, etc.
Old 04-17-2006   #21 (permalink)
Real Name: Jim
Provided Answers: 7
David,
Thanks for the deutsche lesson. I'm sending you a PM.
Jim
'74 Manta ("Sig")
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
