Unanswered: Valve lash adjustment
"Original Opel GT owner 1971, 1973" "Enjoy The Ride!" 1969 GT, 1973 GT "Quazar" 1995 Camaro Z28 New Birthday presents for daughters: 1970 GT, 1971 GT |
Most engines have a screw and a locknut to make valve lash adjustment to which most people is familiar. Opel though uses a single 15mm self locking nut that is rotated by a ring spanner.
For hydraulic lifters, while the engine is working, loosen (one at a time) the nut until the lifter starts to rattle, then tight it just to the point that the rattle stops. From there make 4 clockwise adjustments of 1/4 turn each, one every 15 seconds. Repeat this for all 8 lifters. For solids the gap between the lifter and the valve stem should be 0.30mm with engine hot and working. There are several opinion that it can be done with the engine hot/cold, working/stationary, but the pre mentioned is the FSM method for each valvetrain... It is matter of taste mostly, especially for hydraulic lifters...
#3 (permalink) | |
. . . easier to use a socket with a ratchet wrench though.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 04-07-2006 at 11:52 AM. |
On my solid lifters- I tighten the valve lash bolts (nuts?) with the cylinder at TDC. The bolts (nuts!) get tightened up until they are just snug to the rocker then I back it off about 1/4 turn or until I can just barely feel a little play on the rocker. This is done on a warmed up engine. After putting the valve cover back on, it runs nice and quiet.
Texas Opel Preservation Society Last edited by tekenaar; 04-07-2006 at 02:02 PM. |
I've heard horror stories about making these adjustments, if it's done wrong. So Thankyou! Thankyou! for all advice to pass on.
If my memory serves me corectly- I believe there is a video from Carlilse showing how to to the adjustments. Anyone have a copy to digitize and put in the archives?
Valve Lash ...
Liz - with either the hydraulics or mechanical lifters there is no need to run the motor - with the motor running it is known as the "Hip-deep-in-oil" method!
Here is the hydraulic thread: http://www.opelgt.com/forums/6a-engi...lve+adjustment and the mechanical & Hydraulic both methods:http://www.opelgt.com/forums/6a-engi...ght=valve+lash HTH!
GTJim Opel Owner since last Century! Copyright © 2000-2009 J D Henry All Rights Reserved Last edited by GTJIM; 04-07-2006 at 12:54 PM. |
Gettin valve cover off in GT
I need to adjust my valves (solid lifter 69 engine) and immediately found that I couldnt get the valve cover out from under the body. I was in a hurry so didnt work at it too much, but I had to wonder If I was going to have to remove the hood linkage, a top radiator hose, or maybe even let the tranny down a bit.
Can It be removed without doing something like this? Thanks! |
Methods of Removal ....
People have been known to jack up the motor and remove the engine mounts .... or undo the motor mounting cross-member and lower the motor.
But, usually the rocker cover can be 'wiggled' out from under the firewall overhang.
#11 (permalink) | |
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by tekenaar; 04-12-2006 at 12:29 PM. |
#12 (permalink) | |
#13 (permalink) | |
Looks like English literature (Haynes) has affected MUCH the terminology I use for parts! But I don't get it! The "pair" is bolt & nut. Soooo, in the valvetrain the "bolt" is the fixed stud, and one adjusts by the nut! Right? ![]() Damn, I only had 3 drinks last night! That much of a hangover, that I don't get the simple stuff today??? ![]() baronbors: I am cool, don't worry!!! ;-)
'78 Opel Ascona B 1.6SR ![]() ______________R.I.P.____________ Last edited by gr_diver; 04-08-2006 at 07:34 AM. |
OK-OK- it's NUTS or if your from Norway -KNUTS.
I had to hurry up and write the reply yesterday as 35 eighth graders were leaving my room and 35 more came in. MASS CONFUSION
#15 (permalink) | |
#16 (permalink) | |
Site Admin
valve ajustment
On mechanical lifters (solids) get the car warmed up,turnoff the engine and remove the valvecover. Hook your remote started button across the solenoid,bump the started until you can see that the cam lobe is pointed straight down through the oil drainback hole, ajust that rocker and go to the next one and repeat. On a GT you cannot see the rearmost cam lobe so you will have to stick you finger in the back drainback and feel the lobe (remember to remove finger before bumping starter, or it WILL hurt).
#18 (permalink) | |
Next Time .....
I just ordered (8) Chevy 60 degree V6 (2.8 litre) locking nuts. 99 cents each, can't beat that!
Now all I need is a mechanic willing to loose a finger and get covered in oil?
#21 (permalink) |
valve ajustment
You don't want that guy working on you car anyway, if he loses a finger and gets covered in oil with the engine off, he does not possess the smarts to ajust valves. Sounds like the guy that was changing the tires, maybe he had to find another j-o-b
#22 (permalink) | |
#23 (permalink) |
2 dabs of nail polish/tipex on the crank and cover away from any marks put on for timing and you can get back to that spot every time
#24 (permalink) |
Got it off!
Undid the pasenger side of the hood catch and lifted it. Then I could roll the cover over to the driver side and clear the rockers. Adjusted the valves and got it to the even light clicking that I like from a solid lifter engine.
My wife as been tryiing to wear the rear tires out for two days now! It good to have a fresh engine. She now has a car with NO oil or tranny fluid leaks (automatic trans), not even a drip. "Right Stuff" is great for the pan and even for the back of the rear main cap/engine block. Thanks for the help. PS. Has anybody seen my wife? Maybe an orange GT driven by a giant grin?
#25 (permalink) |
So any luck Liz?I just got a new kick butt head in California.There was a guy picking up a gt when I was there from here"Ceadar"so I beleive we have a new member too.If anyone can use my old head ask it has 1500 miles on it.Thanks Tim
Built not bought |
