Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 7 - Transmission
Group 7 - Transmission Clutch, Transmission
Old 04-28-2008   #1 (permalink)
gt crazy's Avatar
Unanswered: Clutch Cable....
Ok this thing is on my last nerve... I read the book and it said to push in the "fork" to disengage clutch and disconnect it. By fork i guess they mean that arm that goes in and out and the cable is acutally connected to... WELL MY STUPID FORK THING WONT PUSH IN SO I CANT POP OFF THE STUPID CABLE! THIS IS THE SECOND DAY IN THE ROW AND IM GETTING SO MAD IM JUST ABOUT TO CUT IT AND BUY A NEW ONE IM TO THAT POINT. But before I go to the extreme I was just wondering if anybody had any tips on how to take off the cable
gt crazy is offline
Old 04-28-2008   #2 (permalink)
timemachine's Avatar
Real Name: Jim
Provided Answers: 7
It's easy. With a screwdriver or pliers remove the e-ring where the cable goes through the firewall next to the left fender. That will give you slack to slide the end of the cable through the larger hole on the fork. To get the other end off, prop the clutch pedal up and push the cable through the firewall until it pops off.
Jim
'74 Manta ("Sig")
'75 Sportwagon (project)
'72 GT (whenever I get to it)
Sold or wrecked:
'72 Manta Rallye
'73 Manta
'74 Luxus
timemachine is offline
Old 04-28-2008   #3 (permalink)
gt crazy's Avatar
OK now that i feel like a idiot...
Now my question about the spedo cable is should i yank it out or what because i have it loosened but it feels like something is holding it in there. should i give it a tug or whats the deal with that?
gt crazy is offline
Old 04-28-2008   #4 (permalink)
Turbo X's Avatar
Turbo X is on a distinguished road
I suggest not tugging on anything that you don't have a part for, you may find you can't get one, or you need to fix what you have...
that said... spedo cable only come out in one direction try the other end... does it turn?
Turbo X is offline
Old 04-28-2008   #5 (permalink)
gt crazy's Avatar
I havent tried to turn it should i try?
gt crazy is offline
Old 04-28-2008   #6 (permalink)
Turbo X's Avatar
do you have it out of the car?
Turbo X is offline
Old 04-28-2008   #7 (permalink)
gt crazy's Avatar
no the transmission it still in car. and i cant take the transmission out until i take that cable off.
And do you know where the rear engine mount bolts are so i can drop that transmission to get to the bolts on the bell housig?
gt crazy is offline
Old 04-28-2008   #8 (permalink)
Turbo X's Avatar
and yes you can turn it by hand... it your doing it from the engine side and it hooked up to the speedo it should show movement..
Turbo X is offline
Old 04-28-2008   #9 (permalink)
gt crazy's Avatar
You sure i want to acutally spin it? how exactly to you mean spin? Like twist like a clock or rotate it. Because i can move it around it just like its caught on something
and how about those mount bolts?
gt crazy is offline
Old 04-28-2008   #10 (permalink)
Sick with Opelitus
broszzy's Avatar
broszzy is on a distinguished road
Did you unscrew the round nut that hold it on the tranny?
broszzy is offline
Old 04-28-2008   #11 (permalink)
gt crazy's Avatar
i thought so but ill go look
gt crazy is offline
Old 04-28-2008   #12 (permalink)
Turbo X's Avatar
You are talking about your speedometer cable and not your clutch cable...
how do you think a speedometer works? by turning,, it's made of a flexible cable with wire raped around it and that rape can Frey or even brake, but it is suppost to turn free..
as for the bolts read the book
Turbo X is offline
Old 04-28-2008   #13 (permalink)
gt crazy's Avatar
i took one cap type thing off already. And there is like someting circluar going into the tranny just tried to take that off and it just kept spinning and spinning. Its the part that has the rod coming out of that you had to losen up and take out.
I just want to know how to take it out... I dont care if its damaged already big whoop... just how do you take it out
gt crazy is offline
Old 04-28-2008   #14 (permalink)
gt crazy's Avatar
ok that cable just needed to feel the wrath a little bit. it angered so i gave it a good tug and it came out.
gt crazy is offline
