| Group 7 - Transmission Clutch, Transmission |
Unanswered: Clutch out or something else?
#2 (permalink) | |
Clutch
Uber Genius
Its not the synchros. If it was, then the car wouldn't want to go into gear.
I am almost certain that you can just adjust the clutch and fix it (if you mean it is slipping). You can inspect the clutch, though its difficult, by removing the boot off of the clutch fork (on the left side of the tranny) and using an inspection mirror to look into the little space between the pressure plate and the flywheel. As I said, its difficult. You would also need to know how much clutch disk you are supposed to have.
Worked on the car a bit today. I didn't get to tightening the clutch cable yet because I found the brakes on the front were super tight. I bled it out a bit and it loosened but as soon as I touched the brake pedal again it was pretty well locked on. The pad look new, but I try to opel the caliper a bit by wedging a piece of wood in. The wood gave way before the piston did so I'm thinking I might need to get some rebuilt calipers.
Uber Genius
Is the brake pedal at the top when the front brakes are tight? How far can you pull the E-brake up?
In order for the calipers to back off, you need to open the petcock so the fluid has someplace to go. With the petcock closed, you could pry all day with wood and never get anywhere. If the E-brake only comes up a couple notches, then the rear brakes might need adjusting to get the front ones to loosen up.
