Go Back   The Classic Opel Forums > Technical Forums > The Main Tech Forums > Group 7 - Transmission
Group 7 - Transmission Clutch, Transmission
Old 10-06-2009   #1 (permalink)
Rookie
chilly_75's Avatar
Unanswered: Shifter vibrates
What are the likely causes for a shifter vibrating at mid to high speeds? Once I'm up to 55 or more, my steering wheel has some vibration in it, so I'm sure my front wheels are a bit out of balance. But would unbalanced wheels cause the shifter to vibrate this much too? It doesn't vibrate enough to pull it out of gear, but is enough that you don't want to hold onto it for very long, as it will numb your arm. Otherwise, it shifts from gear to gear quite well.
Chilly
chilly_75 is offline
Old 10-06-2009   #2 (permalink)
azopelnut's Avatar
azopelnut
check the spring washers in your linkage. They may have flatten out or may be missing
Paul "azopelnut" Heebink
1970 GT 12A-Rotary 5-speed
1972 GT 2.0, 5-speed
1974 Manta, 1.9 Auto A/C
1975 Fiat X19
azopelnut is offline
Old 10-06-2009   #3 (permalink)
UngerDog
ungermm's Avatar
It could. Once you get a vibration, wobble, or hop at the front, it can easily transfer to other parts of the car. You might want to check your motor mounts and transmission mount too. They may be bad.
Jerry
ungermm is offline
Old 10-06-2009   #4 (permalink)
Kalifornia Kid
DennisGardiner's Avatar
Shifter vibration can be caused from a number of reasons, but often it is just wear in the linkage. I've had to weld up worn linkage parts and re-shim then as well.
Although I have also seen bad engine mounts do the same, but... normally this vibrates the entire car to some extent when that happens.
DennisGardiner is offline
Old 10-06-2009   #5 (permalink)
An unbalanced clutch and/or flywheel will do this too, but it's pretty much apparent before/after a clutch swap!
Old 10-06-2009   #6 (permalink)
I would think that bad "U" joints and/or driveshaft donut would also cause the type of vibration you are describing.
Old 10-06-2009   #7 (permalink)
GT Racing
SantaClaw's Avatar
Real Name: Andreas. H
SantaClaw is on a distinguished road
There's a spring going round the base of the shifter, check if it's there...
-1992 Opel Vectra Expression 2.0i-8v turbo, C20NET
-1973 Opel GT Racing 2.0i-8v 20NE +++
-2009 Polaris 600RR (Snowmobile)
-1972 Bombardier Elan 250 (Snowmobile)
My location
SantaClaw is offline
