Unanswered: a/c fan questions & m?c support
Drive belt for compressor forces the fan to be spaced out from pully. Any idea how much. Or am I better off putting in a electric fan with a thermal switch? Also does some of the master cylinder support bar have to be removed? Thanks for any help Dave |
Dave, if you check out some of the pics in my Willit? Update thread you'll see pics of my engine compartment where the brake rod support has been cut specifically for the GM AC pump. As far as the fan pulley, if the AC compressor has been mounted using the correct bracketry, all you should have to do is line up the pulleys and make sure the fan clears the radiator.
Given where you live you may want to add a pusher fan to go along with the stock fan. On my Datsun I found that to be a big help here. I have it wired to come on whenever the A/C is on and when the temps rise over a certain (I forget what) temperature.
Dave, I can't say about the spacer, I've got the original engine in storage so I don't know about the size, if any was on it originally. I would suggest checking the fan blades to make sure they won't impact the radiator or the fan belts, that may be the only reason to have the spacer installed.
1970-GT
Dave, don't know why your fan is hitting the timing cover, or why you need a spacer, I will have to look at your engine.
Not sure how the pulley system is set up on the stock ARA, my compressor is passenger side mounted and all custom as you know. I mounted a condensor in the front of the GT nose with a pusher fan. This way the radiator gets full air flow. I have a stock 5 blade fan, no fan shroud, and water temp is always low, even in 90+ temp's! I will mount the fan shroud someday. Are you using the stock, large, GM compressor? I use a little Geo Metro type and it works great, more room to mount. The measurement from the water pump mounting surface to the radiator is about 5-1/8" on mine. Lyle |
Detritus Maximus
I am attaching a photo of some Opel a/c parts I have.
In the photo are an a/c pulley, four spacers, and a thermostat housing with an 'extension spacer'. I believe it is all for the ARA a/c set-up that goes on the driver's side. The spacers are (from left to right): #1- A good question. Doesn't look like an Opel installed piece, but it will fit. #2- One I made for fan clearance. 1/2" thick. #3- About 1/4" thick. #4- About 3/4" thick.
#9 (permalink) | |
Detritus Maximus
You are so right namba...I had a little dyslexic brain fart. I didn't transpose any letters, just which side of the car I was picturing in my mind. Everything I have is from the ARA *passenger* side a/c system.
Spacer for GM AC
The 1/2" or the 3/4" spacer will work, the 3/4" is more common when using the 7 blade fan though on the GM set up. The 1/4" is for no AC.
#12 (permalink) | |
Is the 3/4" one available. If so how much do you want for it? Thank Dave |
mine has the double crank pulley on it and has the spacer on the fan and the fan only has about 1/16" from the radiator...im going to remove it and put on an electric one sometime, but need to pull the radiator just to get to the bolts for the fan...
Adam |
#14 (permalink) | |
Detritus Maximus
I'd be happy to supply all the dimensions if you want to have one made. Or if one of our illustrious machinist members would like to do it. I could, but the lathe at work is maintained well enough to easily use it.
#15 (permalink) | |
