Old 01-19-2007   #1 (permalink)
el mero mclain
opelmario's Avatar
opelmario is on a distinguished road
Unanswered: to heat or not to heat
here's the deal guys: i was working on my car in the garage and the heater level switches on my 67 kadett disconnected (actually broke off) from the wire lines. i fixed them at least for now but i can't feel any heat. yes i made sure that the switches were to left to allow maximum flow, but i do not feel or hear any air flow. what might be wrong? please help!
*special note: i did not take it for a test drive, just turned it on inside the garage, does the car have to be moving for the heater to work correctly?
it's not a lowrider, it's an all nighter!
opelmario is offline
Old 01-19-2007   #2 (permalink)
how long did you run the car ? these old cars have a lot more water to heat up than a new one so it takes some time to heat it all
did you have the fan on too ?
Old 01-19-2007   #3 (permalink)
el mero mclain
opelmario's Avatar
ran it for thirty minutes. checked the wires that attach to the blower switch and they seem to be okay. there is a cream colored wire and there is a black one.. switched them around but still nothing.. what could be wrong?
Old 01-19-2007   #4 (permalink)
there may be an air lock in the heater matrix stopping the water getting there , i dont know the kadett well so cant remember if it has the same switch in the water hose but ob a gt there is a valve just before the heater hose enters the fire wall , if the kadett has this it might be in the water off position
as to the wires you dont want advice on them from me i could rewire your radio as a heater but it would be a one off job as it burnt
Old 01-19-2007   #5 (permalink)
el mero mclain
opelmario's Avatar
it's in the ON postion. hm...
Old 01-19-2007   #6 (permalink)
Mario;
Did you flip the deflector handle under the dash? There's a handle to way up under the dash that changes it from running in fresh air from the outside, to using just the air inside the car. It should have a little black ball end on it and it'll click or ratchet sound as you pull it.
Just a thought.
Gene
Old 01-19-2007   #7 (permalink)
in the engine bay or on the dash ?
gene does the kadett use the same valve as the gt in the engine bay ?
Old 01-19-2007   #8 (permalink)
Baz;
If you're referring to me, this handle is in the passenger compartment, under the dash, driver's side, almost in the center up under the dash, it's just a little short handle.
Old 01-19-2007   #9 (permalink)
yes gene you
i was thinking of a water shut off valve ,cable operated , i dont know which way the kadett regulates water to the heater matrix but thats how the gt does it
Old 01-19-2007   #10 (permalink)
Baz;
I was assuming that he already checked that, but, this is something that if you didn't know about it, you'd never find out.
Old 01-19-2007   #11 (permalink)
water shut-off valve . . .
Originally Posted by baz View Post
yes gene you
. . . water shut-off valve is essentially the same piece for both Kadett and GT 1.9 . . . 90° 1/2" hose barbs with internal valve operated by a cable and lever (~70° arc). 1.1 engine screws into rear of head and is different.
Old 01-19-2007   #12 (permalink)
Opel Adventure # 77 NC
kevinfier's Avatar
Real Name: Kevin
kevinfier
The heat control valve on my '69 1.1l is the same as on 1.9l Kadetts.
I would check the lever under the dash, it will cut off all air flow from the heater/blower.
hth
Kevin
kevinfier is offline
Old 01-19-2007   #13 (permalink)
el mero mclain
opelmario's Avatar
soory it took me a while to write back. anyways, yes sirs, i moved the delfector handle under the dash on and i made sure that the valve near the heater core was open. you should hear the blower right?
Old 01-19-2007   #14 (permalink)
Mario;
Yes you should be able to hear the fan, especially on high
Old 01-20-2007   #15 (permalink)
el mero mclain
opelmario's Avatar
hm..... i connected a couple of wires that were disconnected. one was cream colered and the other one is black. here's the deal: they are not in the same group of wires. one is wrapped in a grey tube along with other wires and the other is wrapped elsewhere. hope that i did not confuse you guys more than i am right now. can any of you have the courtesy to send me a pic of what the set up should look like?
Old 01-20-2007   #16 (permalink)
Mario,
If I'm understanding your problem correctly you're concerned with getting the blower to work. Do you have a simple circuit tester light that you can use to determine if electricity is getting to the switch? This was the first electical tester I bought and it helped me figure out ALOT of my electrical problems on my first Opel.
Old 01-20-2007   #17 (permalink)
Mario;
As you have not mentioned it, I have attached a wiring diagram. This is for a '68, but, I think it's better than nothing at all If you PM me your e-mail address, I'll send you the bigger file for easier viewing.
Gene
Old 01-21-2007   #18 (permalink)
el mero mclain
opelmario's Avatar
i do have a tester mr collins but where do i start?
Old 01-21-2007   #19 (permalink)
I'll try to call you later and give you some tips.
