Old 06-26-2007   #1 (permalink)
azopelnut's Avatar
azopelnut
Unanswered: heater a/c fan upgrade
Has anyone retro fit a more modern fan(quieter or more powerful) for either a Opel heater fan or A/C fan ??
Paul "azopelnut" Heebink
1970 GT 12A-Rotary 5-speed
1972 GT 2.0, 5-speed
1974 Manta, 1.9 Auto A/C
1975 Fiat X19
azopelnut is offline
Old 06-26-2007   #2 (permalink)
Lindsay
I looked at smallest (Vintage-Air) A/C & heat combo units, and all appear too large to fit under GT dash. Think if spare tire was removed, combo units might fit in rear deck, but still would have to duct air to front of interior.
What if relay was installed (like headlights?) to supply more voltage to blower motor? More volts may not increase blower output due to blower motor limitations. Should have an extra blower in my parts, will have to take a look at motor.
Does dash pad require removal to remove blower assembly?
Lindsay is offline
Old 06-26-2007   #3 (permalink)
I thought that with motors the number of poles of the rotor determines the ultimate rpm of the motor at full voltage. The resistor will drop the voltage and thus reduce the speed. No?
Paul
Paul is offline
Old 06-26-2007   #4 (permalink)
guyopel's Avatar
Yes to be able to remove the complete housing and duct work and cables .HTH
John
Guyopel
---Thomas Edison
guyopel is offline
Old 06-26-2007   #5 (permalink)
Lindsay
Correct!
Looking at GT schematic for blower wires (Incorrect):
12 GA Black
18 GA Black / Red / White.
Just checked actual early 1972 GT blower motor. 73 GT Blower also is same wiring:
12 GA Red
12 GA Black
Last edited by Lindsay; 06-26-2007 at 08:45 PM. Reason: Schematic Error for later GTs'.
Lindsay is offline
Old 06-26-2007   #6 (permalink)
What about having the blower rebuilt with a higher number of poles motor.... 6 vs 4, or 8 vs 6... Some of the small motor repair shops might be up for the transplant...
Paul
Paul is offline
Old 06-26-2007   #7 (permalink)
No Access
It's actually pretty easy once you have the heater unit out. Just cut the fan section off and replace it with a high CFM pancake style fan. More effecient and quieter, be sure to clean out the heater core inside and out while your at it. That's a trick learned from installing twin carbs.
nobody is offline
