Unanswered: No heat
#2 (permalink) | |
Water Flow.....
Using a garden hose you should have and equal amount of water outflowing the core as you have going in.... any less or if pressure is built up i would suspect a clogged heater core, there are several cooling system chemicals that are available to help with breaking up the scale that is built up.... just follow the instructions on the bottle...... The other possible issue you may have may be the Flap door in the heater box is not moving. you would need to make sure that the lever and cable is still attached to the Flap door in the heater box...........
Cruz "Slot Car" (73 GT) Under Construction ![]() Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. That's relativity. -Albert Einstein |
Heater
Thanks for the info guys. I seem to have the same amount of water coming out as going in, and it really didn't look all that cruddy. Maybe I didn't have enough pressure or something; I didn't use a nozzle on the hose. I also didn't take the hoses off the control valve and flush it. The car has been sitting a while. Just purchased the thing and beginning to learn about it. I will try more pressure and also flushing the valve/hoses. Thanks again.
Cooling System Info Link
Cooling System Information Link (includes heater info):
http://www.opelclub.com/CoolingSystemOct2006.pdf |
A lot of crud accumulates in the heater valve. It's attached to one of the heater hoses near the carburetor and it has a 90 degree internal turn. Remove the valve, flush it. You might have to physically poke around in there to clear your blockage.
I have the same problem in mine. My lever would only move 3/4 of the way. I found that the pivot point on the lever is worn and in order to get it to move all the way to the right I push it over as far as it will go then push in and to the right to make the lever travel all the way to the right. I still had no heat and then discovered I have a broken cable as well. Looks like I am in the market for a new cable and heater controls!
