Old 04-01-2008   #1 (permalink)
michaedo's Avatar
Unanswered: heater hose connection
Howdy folks,
A couple quick questions if I may:
Right along side the oil pressure sender is a spout for the heater hose. I would like to plug this up. I'll be danged if I can find a proper threaded plug for this hole. More than likely it's a strange metric pipe thread size. Perfect. Where the heck does one find something that will fill this hole?
While we're down by the oil pressure sender. I'm not sure if it's working.
Upon ignition the oil pressure gauge slams to it's stop on the right side never to move again till the engine is turned off. The oil light does it's job, going out when the oil pressure is up. Is the light also run off the pressure sensor?
If that's the case maybe my gauge is ka-put.
And another thing...is the windshield wiper parking capability incorporated in the motor itself? My wipers no longer park. Although I've gotten the timing down pretty good to park them proper, it would be nice to have that working right.
That's it for now,
thanks,
Don.
michaedo is offline
Old 04-01-2008   #2 (permalink)
jmbinjax's Avatar
jmbinjax is on a distinguished road
If it's in the block, it's not a spout for anything. It originally had a plug in it. The thread size is metric 14 x 1.5. If you can't find a plug that size (goodluck) you can get an adapter to 1/8" npt then put a plug in it or a drain cock. egauges.com has the adapter, part #R7963. hth
jmbinjax is offline
Old 04-01-2008   #3 (permalink)
michaedo's Avatar
thanks, that's exactly what I was needing to know.
Don.
michaedo is offline
Old 04-01-2008   #4 (permalink)
Try swapping the leads on your oil pressure sender. The parking for the wiper blades is in the motor housing, there is a plate inside with 4 wiping tracks that rotate with the motor and stops the electrical current to the motor when the wiper switch is off or the foot pedal is not depressed. HTH.
Old 04-01-2008   #5 (permalink)
michaedo's Avatar
Thank you Namba,
The previous owner had installed a variable type switch rather than the regular 2 speed one and I think something got fubared in the process. I'll bust 'er open and see what there is to see.
Thanks again.
Don.
michaedo is offline
Old 04-01-2008   #6 (permalink)
michaedo's Avatar
Oh yeah, on the oil pressure sending unit, it's a no brainer connection - one is a spade type, one is a stud/nut type. No confusion there. I did have the oil gauge out though. Perhaps I crossed the wires at that point? Thank you for your idea, I'll check tonight.
Don.
michaedo is offline
Old 04-01-2008   #7 (permalink)
Another "Opinion"?
"If it's in the block, it's not a spout for anything. It originally had a plug in it."
No - It could be a 1975 or later Opel block, which did have
a water connection located there. If so, you can cap it (with a thick rubber cap and a hose clamp).
(My question: Why are "instructions" here, that don't reflect a sufficient base of knowledge of variations on Opels, not labelled upfront as "opinions"?)
Anonymous D is offline
Old 04-01-2008   #8 (permalink)
Site Admin
Gary's Avatar
Real Name: Gary
Because it's a community Dave where people freely share their knowledge. Not labeled as instructions or opinions. You do not need to be an expert to post a response and if that response is not correct others will help out. We're expanding the knowledge base for all here and encouraging all members to participate.
Gary is offline
Old 04-02-2008   #9 (permalink)
Exclamation Best block coolant plug solution . . .
Originally Posted by jmbinjax View Post
Originally Posted by michaedo View Post
Howdy folks, a couple quick questions if I may:
While we're down by the oil pressure sender, I'm not sure if it's working. . . .
And another thing...is the windshield wiper parking capability . . .
That's it for now,
thanks,
Don.
If it's in the block, it's not a spout for anything. It originally had a plug in it. The thread size is metric M14 x 1.5. If you can't find a plug that size (goodluck) you can get an adapter to 1/8" npt then put a plug in it or a drain cock. egauges.com has the adapter, part #R7963. hth
. . . is to remove that '75 FI heater hose connection, send it to me , buy a 3/8" NPT (closest to M14x1.5) drain fitting at a hardware store, put either pipe dope or teflon tape on the threads and install that in it's place.
. . . you kill two birds with one stone - plug the metric-threaded hole AND can easily drain block completely without much effort whenever needed!
Old 04-02-2008   #10 (permalink)
jmbinjax's Avatar
(My question: Why are "instructions" here, that don't reflect a sufficient base of knowledge of variations on Opels, not labelled upfront as "opinions"?)[/QUOTE]
Excuuuuuuse Me!!!
jmbinjax is offline
Old 04-02-2008   #11 (permalink)
I am not certain but I think you can get the correct plug from McMaster-Carr if you don't want to bugger the threads.
Old 04-02-2008   #12 (permalink)
michaedo's Avatar
Got a 3/8" plug. Seems to fit the bill, and the hole, ok.
Doesn't seem to have messed up the threads in the block.
Thanks all,
Don.
michaedo is offline
