Lurker
Unanswered: Heater valve cable routing
Does the heater box need to be removed to run this cable through? I'm getting the feeling that it does, because it's a 2 part cable and the other part goes to the far (passenger) side of the box. I don't know how I'd get it to that point, either. |
The cable from the heater to water control valve is a one-piece item. It is clipped to the water manifold tubes and may be hard to remove because of that. I can't advise on how to remove the cable with the heater installed, I had Willit? stripped when I made up a new set of tubes and replaced the heater control panel. Maybe a call to OGTS will be of assistance, they have replacement cables IIRC.
UngerDog
It's a two piece cable. One line goes to the valve. The other to the right side of the heater assembly. The cable to the valve goes under the box and between the two heater pipes. The other cable goes over the assembly and connects to the baffle linkage on the right side. Both cables are continuous and form a loop near the middle at the lower heater control lever on the dash. I don't think there is any way you can connect all this without taking the dash and heater assembly out. I guess if you wanted to, you could route a separate single push/pull cable from the water inlet valve to somewhere under the dash so that you would have the use of the heater without all the work.
Jerry |
Although I didn't do the work myself, I had the cables and the heater control panel unit replaced. I know they had to take off the dash panel, but I dont think they had to pull the heater box. It wasn't mentioned to me if they did. You can always open the heater valve manually when you need it.
Lurker
Remove the dash?
Dang, I was afraid that was going to be the answer.
![]() I tried manually opening the valve, but it's almost impossible to get it to the "just right" setting that way. Oh, well. Good thing we don't need heat in Wisconsin! |
1971 GT
Here's some pics from when I had it out this summer. You can see that the cable is clamped to the heater and the more stuff that comes out, the better.
I purchased a new valve from OGTS, and it stays open really well. (This is on another GT, not the one with the new cables and control panel). The cable is there, but isn't connected and doesn't work. I put the end of it in the valve to hold it, but I don't know that I really need to. HTH.
#9 (permalink) | |
Lurker
The valve moves fine, but every time I get it set, the outside temperature changes on me and we end up baking or freezing. |
The only way to fix the heater cables is to pull the dash
, sorry but the truth hurts.
Kalifornia Kid
After you pull the dash.
Pull the heater box out of the firewall. Why? The heater cable goes through a large rubber boot (seen in picture 3) then it routes between the two water tubes, finally clamped between the front tube support and finally exits out of the rubber gasket under the hood.Note: the clamp that holds the two water tubes "usually" holds the heater valve cable so tight that you can not pull out the old cable without loosening the clamp bolt.
#13 (permalink) | |
UngerDog
Jerry |
#14 (permalink) | |
stuck casing
i'm also trying to install a new heater cable before the cold stuff hits. i've removed the bolt at the top of the plastic blower/heater case and the two nuts at the bottom but i can't budge the case even a half inch. i've looked all around inside the passenger footwell but i can't see anything holding it. i don't see anything inside the engine bay either. is there a hidden clamp that holds the inlet/outlet tubes? i think i have to pull the case to attach the cable on the extreme right side and to thread the other end into the engine bay to the valve. has anyone attached cables without pulling the case?
bob |
#16 (permalink) | |
. I think you have all the bolts out so if you disconnect the heater hoses and the cable and as long as the air duct tubes are loose or off I believe the whole unit should pull out. I do remember that there is a sponge sealer around the opening but I would find it difficult to believe that it would stop you from pulling the unit out. Be careful not to put too much force on the unit as it is pretty brittle and easily cracked. BTW you do have to pull the case.
#17 (permalink) | |
1971 GT
![]() I don't recall any bolts other than those you see, but mine did hang up on the vinyl piece at the side of the footwell.
