Unanswered: Help with radio connections
It powers up ok, and I when I crank up the volume I can barely hear anything from the speakers. I checked the connections and what I have is three wires come out from the radio (blue, green and grey) plus the antenna that is hooked up (but is telescopic and I can't get it extended) Then I have a little junction box were these 3 wires are connected to the 2 front speakers (2 wires per speaker, each one connected to a color..but not sure if it's right) Now. what I'm looking for is a wiring diagram for these radios, so I can at least be sure everything is ok in the wiring before I start checking everything else, can some one explain how every thing is supposed to be connected? Also.. would a faulty antenna be the cause of not getting volume? |
#2 (permalink) | |
Real Name: Joe S.
Are the speakers original? If so, probably paper coned and shot. do you hear buzzing and charlie brown teacher like sound? getting a 404 error whenever i try to go to the wiring diagram forum so i can't help you with the wiring.
I love opels AND buicks! |
#3 (permalink) | |
Jeff '73 GT,5spd,Recaro,EDIS4 2.2 EFI by MegaSquirt, Ali Flywheel w/S10 Clutch, Electric Fan, Roller Rockers, Venolia Pistons, 6 Cyl Intake w/ Custom Injection, 15" Wheels,Lecarra,F&R Sway Bars,Custom Exhaust,1" Sport Spring,Koni Reds,Big Brakes,3 Core Ali Radiator,Hse of Colors Kandy Pagan Gold. 123 WHP @ 6800 RPM ![]() '64 VW Karmann Ghia '08 BMW M3 Last edited by markandson; 01-27-2009 at 10:24 PM. |
Real Name: Jim
![]() Provided Answers: 7
I would definitely plug an antenna into the radio and extend it outside the car before I jumped through a lot of other hoops. The radio in my old '69 chevy behaved very similarly without an antenna due to an auto noise limiter circuit (ANL) that kept gain very low without an antenna.
Jim
Yeah, I really have to try that because when I unplugged the antenna..nothing happened at all. At this moment the antenna is plugged in but is stuck in the down position (I put a bit of grease to pry it loose but I think I have to use force to get it unstuck)
Your chances are very high that the wiring connections you need are actually printed on the upper or lower lid directly on the radio.
Dieter
Real Name: Jim
Okay, dumb question. Did you try the cassette player? That would tell you something. Unless something is disconnected it's hard to imagine the PO left it wired wrong. If the cassette doesn't work, to check the antenna connecter you can just insert a piece of unshielded wire into the center of the connector. About 33" is the proper half wave for FM, but it doesn't much matter for this.
Last night I tried it with a new antenna (just plugged it in, extended it and nothing) so I'm guessing that it's the speaker connections.
I tried looking at the radio for a wiring diagram but I can't find a way to dismount the radio...and Since I really don't need to becaus all the wiring is exposed, I think I'll just try diferente connections |
