Answered: Any way to oil heater fan bearings?
Most Helpful Answer - Posted by BQS4
#2 (permalink) | |
If you are going to take the motor completely out of the housing a "off set" screwdriver is very useful. One of the screws that holds the motor bracket in place is set under the cowling and you only have about a inch to work in. It looks like they installed the motor first onto the heater housing and then attached the housing to the firewall. If you have a offset screwdriver it is a pretty simple removal. 5 screws that hold the motor cover and 3 screws that hold the motor bracket to the heater housing, unclip wire motor is out.
George. |
Detritus Maximus
The quick and easy way to oil the bearing is to drill an 1/8" hole in the center of the cover. This is right over the upper bearing/spindle shaft of the fan. You can then seal the hole with a very shrot screw or a piece of tape. I would not do anything more permanent to seal the hole as once the fan squeals, it will squeal again and this will be a routine procedure.
Taking the cover off and cleaning out the fan box is a very smart thing to do.
